a nother 2.8 to 3.4 swap need help
Old Jan 20, 2009 | 07:14 PM
diablo666mew's Avatar
Car: 89 camaro RS convertible
Engine: 305 tbi
I was up late last night reading . all most all the 3.4 swap and got alot of info about it . but still have some question that i kind of got answers from but not 100% answers. I have a 1993 motor from a camaro to put in my 86 2.8 .i want to just swap the block and use the top in of my 2.8. now my question what do i swap in on the top end what fuel injector do i use the 2.8 or 3.4? cand i swap over my accessory starter from the 2.8 altnater brackets and so on to my 3.4? do i have to remove the heads from the 3.4 or can i bolt the 2.8 intake to the 3.4 heads ? cane i use the 3.4 harmonic balancer ? what about the 2.8 Distributor will it work fine on the 3.4?? what about my 700r4 trans can i use it on the 3.4 ? any other thnigs i should watch out for let me know thank you i hope you guys can anser my question . Mel
Old Jan 20, 2009 | 08:16 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: a nother 2.8 to 3.4 swap need help
You need to transfer the intake manifold/distributor from the 2.8 onto the 3.4 w/ 3.4 injectors if you want to use the stock computer/harness, otherwise you need to swap in the 3.4 harness/ecm as well. You can't tune with the 3.4 ecm either, noone's cracked it yet.
Old Jan 20, 2009 | 08:37 PM
Engine: 305 tbi
so you are saying i can use the 3.4 injectors with my 2.8 computer/harness?
Old Jan 20, 2009 | 08:48 PM
Engine: 305 tbi
or was that a type O ?
Old Jan 20, 2009 | 09:43 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
really? no one has cracked that ecm? thats really weird.
OP...use the 2.8 injectors, they're 15 lb/hr the 3.4 injectors are 17 lb/hr and will cause it to run very rich.
Old Jan 20, 2009 | 09:57 PM
Engine: 305 tbi
ok i will use the 2.8 any more info for me
Old Jan 21, 2009 | 06:54 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
No you need to use the 3.4 injectors or you will run too lean for the increased CI, it really doesnt run that rich. dont use the 2.8 injectors. basically you reuse your intake, fuel rail, distributor, timing cover, oil pan, exhaust manifolds, and keep your 2.8 ECM. you use the 3.4 balancer, flexplate/flywheel, block, heads.
Old Jan 21, 2009 | 08:11 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Use the 3.4 injectors!
Use the 3.4 balancer
Use the 3.4 fly/flex.. if your 3.4 came with the wrong one for your application, go buy one for a 3.1l
I made a post about this along time ago explaining EXACTLY what parts need to be used.
Old Jan 21, 2009 | 05:40 PM
Engine: 305 tbi
3.4 injectors so will they work with the 2.8 wiring harness? i read another person forum had problem getting the timing wright is that hard ?
Old Jan 22, 2009 | 05:40 AM
Dale's Avatar
Engine: 350 S-TPI
yes the injectors will work with your current wiring and ecm.
Dunno anyone who has had problems with timing. They must have put it together wrong.
Old Jan 22, 2009 | 05:59 AM
Engine: 305 tbi
thank you for the help . any 1 else fell there is any thnig i need to know let me know i am starting next week on the swap
Old Jan 22, 2009 | 10:07 AM
Dale's Avatar
Engine: 350 S-TPI
https://www.thirdgen.org/forums/v6/3...highlight=tech
Cleotiz
Jan 6, 2018 08:56 PM
Digs_do_it89
Aug 30, 2015 10:24 AM
E Rod
Aug 28, 2015 05:17 AM
86Base
Aug 8, 2015 01:34 PM
92projectcamaro
Aug 6, 2015 01:20 PM
