dyno results
Old Mar 14, 2009 | 01:26 PM
project89's Avatar
dyno results
i know alot of u guys dont look int he power adder section so here is a link to the thread with the results form the dyno
https://www.thirdgen.org/forums/powe...ts-inside.html
Old Mar 16, 2009 | 07:26 PM
project89's Avatar
Re: dyno results
im shocked 52 views here and over 250 in the pa section of the boards and not one reply
Old Mar 16, 2009 | 07:46 PM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
Re: dyno results
did you get the prob fixed with the rpm range..so you can go full boost at full rpm
Old Mar 16, 2009 | 07:50 PM
project89's Avatar
Re: dyno results
not yet tom maybe i just need to stop by radio shack and pick up 2 resitors to fix the ignition problem
Old Mar 16, 2009 | 07:52 PM
snowman383's Avatar
Engine: 350 crate
Re: dyno results
got another ? where did you get the piping for the kit..and would install be reverse in a firebird sense the battery is opp side as your maro
Old Mar 16, 2009 | 07:54 PM
project89's Avatar
Re: dyno results
yeah u just revrese the piping. or u can go buy the camaro battery cables and move the batter to the other side
i got all my tubing from summit
Old Mar 16, 2009 | 08:01 PM
snowman383's Avatar
Engine: 350 crate
Re: dyno results
wouldn't have to buy it ..my pos cable is ran on the bottom of the fan shroud..i could move it that way,,but what about the charcoal canister,,,and where did you put the maf sensor
Old Mar 16, 2009 | 11:41 PM
project89's Avatar
Re: dyno results
i no longer run a maf, but when i did it wa son the inlet side of the turbo.
charcol can i removed and vented the one line
Old Mar 17, 2009 | 05:35 PM
project89's Avatar
Re: dyno results
another video from the dyno
http://videos.streetfire.net/video/641533.htm
Old Mar 17, 2009 | 05:39 PM
snowman383's Avatar
Engine: 350 crate
Re: dyno results
you got a pic of the vented lines ..so i don't mess anything up
Old Mar 17, 2009 | 05:40 PM
project89's Avatar
Re: dyno results
when u take the charcoal can out there will only be one line running back twards the tank, thats the one u leave vented.
i dont think i have any pics
Old Mar 17, 2009 | 05:44 PM
snowman383's Avatar
Engine: 350 crate
Re: dyno results
ok what about the other ones..my canister has aelectrical plug on it for a sensor or something..also do you still have your old turbo
Old Mar 17, 2009 | 06:18 PM
project89's Avatar
Re: dyno results
no i got rid of my old turbo, just unplug the electrical conector and leave it there.
its actually not a sensor its a plug for the purge valve on the charcoal can. if u get a check engine light with it removed. u can remove the purge valve off the top of the can and just plug it back in and zip tie it off to the side out of the way
Falcon50
Aug 22, 2020 03:26 PM
LT1Formula
Oct 8, 2015 08:34 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
