A/C Delete Pulley
Old Mar 17, 2009 | 04:46 PM
autoholic's Avatar
Car: 1988 Camaro RS, 1972 Dodge Dart
A/C Delete Pulley
I know they sell these for the V8's but can I get one for my 88 2.8 V6 RS?
Can anyone give me a part number please or tell me it the V8 one's will fit?
Thanks guys & gals
Old Mar 17, 2009 | 05:28 PM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
Re: A/C Delete Pulley
i have been wondering the same thing..i need one also...
Old Mar 17, 2009 | 06:51 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
They are the same.
Speeking of...I have one that I wont need anymore and I only used it on my 3.1 for about a month and a half....shoot me a PM if anyone is interested.
Old Mar 17, 2009 | 06:54 PM
project89's Avatar
chances are u dont even need it.
aparently on some cars u can just go right fromt he power steering pump to the tensioner/alt.
this worked great on my car but a few ppl have reported the belt would rub the water pump,so its possible over the years that the ps pump has 2 dif fmounting locations.
only way to see if it will work for you is to try it
Old Mar 17, 2009 | 06:56 PM
grimmcs's Avatar
Car: 91 Camaro
^^Ya know, I was just going to edit my last post to add that....but you beat me to it.
Old Mar 17, 2009 | 07:16 PM
snowman383's Avatar
Engine: 350 crate
but doing it with out the delete pully wouldn't you need a shorter belt.to make up the diff..
Old Mar 17, 2009 | 07:24 PM
HONDASLAYER's Avatar
Car: 1983 CAMARO Z28
Engine: 305ci
Transmission: 5 speed
Axle/Gears: ?
a buddy at work was telling me today that all i should have to do is when i go to buy my new belt and they ask if i have a/c just say no. they should give me the proper belt for my car without an a/c unit (shorter). Is this true or will this work?
Old Mar 18, 2009 | 01:10 AM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
Yeah, just say you don't have A/C.
As for the A/C delete pulley, I think Autozone sells one, or SummitRacing.
Old Mar 18, 2009 | 05:55 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
For serpentine belt engines:
Part number at your local store interchanges with Drive-Rite 815K6, need to replace mine as it got coolant on it when I resealed my water pump.
To delete the compressor, you need to remove it from the car. Then, you remove the rear bracket from the power steering pump (but leave the rear bolts in place as they WILL leak if you remove them) and the front 2 bolts, from the head and the water pump (just loosen the one on the w/p). Loosen your pressure hose at the back of the p/s pump, and tilt the pump to the center of the engine until the second bolt hole next to where the original bolt came out of is aligned with the hole in the cyl head. Put the top bolt back in this second hole, tighten the bolt on the power steering pump and the pressure line at the back of it, install your belt, and crank her up.
Old Mar 18, 2009 | 06:44 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
That's weird... I went to O'reilly's and asked for a belt for a 3.1 with no a/c. He looked it up and it came up a 92.5" belt. I noticed on the sticker, it gave 2 different belt routings for a/c and non-a/c setups. I bypassed the a/c and it did get VERY close to almost rubbing near the top of pump and the bottom of the tensioner. Hmmm....well, GM had it routed like that. Go figure.
Ken
Old Mar 18, 2009 | 08:08 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Ken
The only way it works with the shorter belt is to alter the mounting of the P/S pump as I described above. I've tried it without, and I ended up returning the belt because it was too short to go over the tensioner without changing the position of the P/S pump (before I knew about the second hole and saw the A/C-less '91 in the junkyard).
Oh, and that belt part number I posted above is for a non-A/C, non-AIR car, so those WITH AIR would have to get a different belt.
Old Mar 18, 2009 | 08:25 PM
snowman383's Avatar
Engine: 350 crate
good thing i saw mavericks post..i pulled the a/c off earlier today and i have a second belt already got lucky..the smaller one...but my thing is i can go straight from alt to power steering pump..and it makes it to where i have to put rad hose through it..i will look tomorrow when i get home from job interview..and see about moving power steer pump like he said..also i need a power steer pump bracket mine is broke at the top bolt..anyone got an extra..please remember i'm broke
thanks mav for the info
Old Mar 21, 2009 | 01:32 AM
snowman383's Avatar
Engine: 350 crate
ok got my belt on ..took the bracket off the back of the power steering pump and pushed it towards the water pump and the belt went on with no prob..have plenty of clearance from the water pump also...
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
