Intake Swap Question
Old Mar 29, 2009 | 04:30 PM
flowmasterRS's Avatar
Car: 1991 Camaro RS
Engine: 3.1L MPFI
Axle/Gears: stock
I'm looking to swap the stock 3.1L air intake (L-shape, cylinder filter) for a V8 or old 2.8L dual snorkel intake.
I only have one question though, what do I do about the sensor that plugs into the air box on the stock 3.1L intake? Can't leave it unplugged can I?
Old Mar 29, 2009 | 06:23 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Intake Swap Question
There will be a hole in the box for the air temp sensor, obviously...
Old Mar 29, 2009 | 07:21 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
maverick is right, the sensor will go right in the other air intake. It shouldn't take more than a few minutes to do.
Old Mar 29, 2009 | 07:45 PM
Car: 1991 Camaro RS
Engine: 3.1L MPFI
Axle/Gears: stock
Okay I just wanted to check and make sure that it would work out okay, I have yet to get my hands on one. Thanks!
Old Mar 29, 2009 | 08:36 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
Might be hard to see, but the sensor is on the top center of the picture.
Here's the link to the original picture (scroll over the picture to find a note that locates the sensor)
http://www.flickr.com/photos/25961017@N05/3344343611/
Old Mar 30, 2009 | 07:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Only the 2.8l Y type air cleaner intakes will have the opening for the IAT sensor. The TPI air cleaner intakes don't have it.
To move the IAT from the cannister air cleaner to the Y air cleaner the wires need to be extended. If you don't do this right away leave the IAT plugged in and secured (ty-wrap) in the area of the old air cleaner.
Note that you will also need a filler piece between the Y air cleaner and the rubber tube from the TB. In the picture above the MAF fulfills this role.
RBob.
Old Mar 30, 2009 | 09:58 AM
project89's Avatar
i have a 2.8 dual snorkle air cleaner assembly if ur intrested in driving out to my shop to pick it up, its to big to ship
only mod to it is the silencers in the bottom have been removed but the bottoms of the box have not been cutout
Old Mar 30, 2009 | 03:00 PM
Car: 1991 Camaro RS
Engine: 3.1L MPFI
Axle/Gears: stock
Hm, where are you located? And how much would you charge?
Plus, I think I need the bumper with the slits in it to let the intake function properly. Either way, I'm still interested, one has to come before the other.
Old Mar 30, 2009 | 04:14 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Woohoo, road trip! Too bad I'm in the Pacific Northwest or I would tag along and check out that beast of a V6. Oh, and not to mention my car is torn apart.
Old Mar 31, 2009 | 04:03 PM
project89's Avatar
central nj, i think im about a 30-45 drive away form philia, i donno hows 50 bucks sound
Old Mar 31, 2009 | 09:09 PM
Car: 1991 Camaro RS
Engine: 3.1L MPFI
Axle/Gears: stock
Okay sounds good. i'll save up some cash and get back to you. If someone wants to take it off your hands in the meantime it's okay, I might be a while.
Frozer!!!
Jan 19, 2024 04:55 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
reiderz iroc
Aug 13, 2015 04:57 PM
