how could i put a remote start on a 89 camaro rs 2.8
Old Apr 3, 2009 | 12:48 PM
Lestrey08's Avatar
Car: 84 camaro berlinetta
Engine: 2.8 V6
Transmission: 700 r4
when i crank it up i have to push the gas a lil bit then i have 2 drive wit one foot on gas and one on tha break i figure i wont be able 2 start it remotely till i fix that please help
Old Apr 3, 2009 | 01:01 PM
50bmgshooter's Avatar
Re: how could i put a remote start on a 89 camaro rs 2.8
pretty sure you need to have that fixed first
Old Apr 3, 2009 | 01:05 PM
Lestrey08's Avatar
Engine: 2.8 V6
yeah but i dnt knw y it's doin that could it be i need 2 adjust the idle?
Old Apr 3, 2009 | 01:19 PM
idle timing fuel ?
time for a complete tune up
Old Apr 3, 2009 | 01:29 PM
Lestrey08's Avatar
Engine: 2.8 V6
complete as is spark plugs, wires, distributor cap?
Old Apr 3, 2009 | 01:33 PM
HtOwNs 87Rs's Avatar
yea thats a good idea while your down there....maybe coil as well if it looks orginal. Radiator flush and oil change wudnt hurt. Sounds like a half/full days of work
Old Apr 3, 2009 | 01:41 PM
Lestrey08's Avatar
Engine: 2.8 V6
yea dat all sounds good thx everybody
Old Apr 3, 2009 | 03:37 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Id check all your vac tubes as well and your injector and fuel filter.
Old Apr 3, 2009 | 04:07 PM
91chevywt's Avatar
You shouldn't have to touch the throttle on startup on a fuel injected car, so keep that in mind. About what RPMs do you have to keep it at so it won't die? A good tuneup is a good start though.
Old Apr 3, 2009 | 08:15 PM
Lestrey08's Avatar
Engine: 2.8 V6
yea I have 2 hold the gas till it reaches operating temps and it will idle nicely
Old Apr 3, 2009 | 08:53 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
maybe retime it. that has a lot to do with idle.
Old Jun 29, 2009 | 06:12 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Might also want to change out the fuel filter and make sure your O2 sensor is functioning properly. Seafoam works will in the fuel line and crank as well.
Frozer!!!
Jan 19, 2024 04:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
86Base
Aug 8, 2015 01:34 PM
Amillionoh7
Aug 7, 2015 01:24 PM
