egr block off q&a *good info inside*
Car: Many
Engine: Several
Transmission: Automatics
so all i need to do is block off the hole in the intake? do i need to cap the vacuum lines that go to the existing egr? ive searched but still foggy on the issue.
Car: Many
Engine: Several
Re: egr block off questions
seeing that its easier to just block off the opening of the egr, i did that. i used an old license plate but it really wasnt heavy enough, so i made an angle piece out of aluminum, no leaks but i reused the old gasket. when i get a chance i will put some copper rtv on it. the bolts wouldnt go down flush because they have a bit of a shoulder on them, and i dont have ony washers so i used a couple 3/8 nuts i had in my tool box. i drove a little and no codes came up. it idles at about about 850 rpm. i also just put a screw in the vacuum line so it wouldnt leak.
Car: Many
Engine: Several
i was going to block the tubes off but they are harder to get to.
Car: Many
Engine: Several
save me $35. The egr (exhaust gas recirculation valve) takes exhaust gasses back into the intake. it only does this 1. when the car is warm (not hot just normal) 2. under cruising throttle. WOT makes no difference, but when the valve is stuck open it lets too much of the exhaust gas into the intake, causing a lean condition, and hesitation while driving. the later V6's use a digital egr, which is very expensive to replace. so its more popular on the newer cars to do this.
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
I know what the EGR does, what does removing do besides save you money? Or is there no real difference besides a small weight reduction?
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
I just hammered a wad of aluminum in my manifold & spread some jb weld over it. Looks like crap but I don't really care about the motor in it right now. I have heddmann headers so the ex. side didn't matter. Removing it doesn't really do anything performance wise, but makes it easier to work on. Less clutter.
Car: Many
Engine: Several
For me, it saved me money. I dont think it affects anything, but its common to hear mpg loss, and gain. I dont know what it was before, Ill let you know what it is now.
Car: 2006 GTO
Engine: LS2
Transmission: M6
I had to replace my EGR, was getting horrible mpg because it was stuck open, replaced it and ran better. If I knew it could run ok without it, I wouldnt' have spent the $35. Oh, and the $110 after breaking the solenoid...Oh well, live and learn, right?
Car: Many
Engine: Several
i was worried that it was a vacuum issue and not a bad egr also. this was it just shuts the car up for me. i know it has a bad vacuum leak bc when i change the heater controls it hisses at me for awhile before switching.
Car: 2006 GTO
Engine: LS2
Transmission: M6
Everything on this camaro was original factory parts when I bought it, I was amazed it made the trip home. All ignition parts were bad, replaced all those. Replacing the EGR had the largest effect that I noticed.
Car: Many
Engine: Several
New2Chevy
Sep 28, 2015 12:35 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
