mpg
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
Re: mpg
24-27 on the hwy, maybe 28. I did a 100 mile trip today, started with 3/4 tank and still have half a tank. Then again, maybe my fuel gauge is broken.
It's my daily driver and I only spend about $20 every 1.5-2 weeks on gas.
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Re: mpg
I have a quick ? for you coolrims................when you first put your 3.4 in if I can recall right your gas mileage was crappy from a previous post of yours I was reading. Did you ever figure out what the problem was? I seem to be having the same problem now.
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Car: Many
Engine: Several
Transmission: Automatics
Re: mpg
Yr Model Trans Engine
code/type CR Displ. HP Torque Induc-
tion Manual
std. Manual
opt.
(G92) Auto
std. Auto
opt.
(G92)
89 RS M5,A4 LB8 V6 8.9:1 2.8 (173) 135@4900 160@3900 MFI 3.42 ---- 3.42 ----
89 RS M5,A4 LO3 V8 9.3:1 5.0 (305) 170@4400 255@2400 TBI 3.08 ---- 2.73 ----
89 IROC-Z M5,A4 LO3 V8 9.3:1 5.0 (305) 170@4400 255@2400 TBI 3.08 ---- 2.73 ----
89 IROC-Z A4 LB9 V8 9.3:1 5.0 (305) 195@4000 295@2800 TPI ---- ---- 2.73 ----
89 IROC-Z M5 LB9 V8 9.3:1 5.0 (305) 220@4400 290@3200 TPI 3.08 ---- ---- ----
89 IROC-Z M5 LB9 V8 9.3:1 5.0 (305) 230@4600 300@3200 TPI ---- 3.45* ---- ----
89 IROC-Z A4 L98 V8 9.3:1 5.7 (350) 230@4400 330@3200 TPI ---- ---- 2.77* ----
89 IROC-Z A4 L98 V8 9.3:1 5.7 (350) 240@4400 345@3200 TPI ---- ---- ---- 3.27*
*Borg-Warner rear axle
Car: 89 RS
Engine: 2.8
Re: mpg
A great place to get fuel mileage esimates is http://www.fueleconomy.gov/feg/sbs.htm Here is the link for a v-6 auto.
