adding an oil pressure gauge
Old Apr 16, 2009 | 07:48 AM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
i dont want to lose the factory gauge but its not accurate at all. it looks like their is another spot to add a sending unit by the filter. has anyone added a gauge and left the factory one?
Old Apr 16, 2009 | 04:46 PM
sloick's Avatar
Car: Many
Engine: Several
Re: adding an oil pressure gauge
some one knows. come on.
Old Apr 16, 2009 | 09:20 PM
84olmpcboy's Avatar
Car: 84 olympic edition camaro
Engine: 2.8
I got a t-fitting and just put in the idiot light plug and the new gauge plug and it works good. I don't know if there is a spot there for another sensor or not.
Old Apr 16, 2009 | 10:38 PM
sloick's Avatar
Car: Many
Engine: Several
do you have a picture by any chance?
Old Apr 16, 2009 | 10:45 PM
chris.niemann84's Avatar
Car: 1985 IROC Z28
Engine: L98 - 350/650 Holley DP
Axle/Gears: 3:83 Full Spooled
not sure how your 2.8 is setup for sure, but my 350 has another plug right next to the distributor on the back of the block. if you take that out, you can use that one. if you're factory gauge isn't working, leave it where it is, just put in an aftermarket gauge in that plug on the block... no sence in having two oil pressure gauges when only one works....
Old Apr 18, 2009 | 05:00 PM
84olmpcboy's Avatar
Engine: 2.8
Both of my gauges work. I like my aftermarket one so I can see what the presure is and I like the idiot light as a good warning light
Old Apr 18, 2009 | 06:02 PM
sloick's Avatar
Car: Many
Engine: Several
do you know the fitting size of the T off hand?
Old Apr 18, 2009 | 07:26 PM
84olmpcboy's Avatar
Engine: 2.8
I forget what size it was. You can just take the sensor with you when you buy it to make sure its the right size.
Old Apr 18, 2009 | 09:05 PM
sloick's Avatar
Car: Many
Engine: Several
thats awesome! thank you for your help.
Old Apr 18, 2009 | 09:07 PM
sloick's Avatar
Car: Many
Engine: Several
man, i wish it were further up on the block, i just changed the oil.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
