3,1 FireBird engine instead of 2,8 Camaro engine
Old Apr 16, 2009 | 10:19 AM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
Hey guys,
can somebody tell me if I can swap the newer 3,1L engine of a 91 firebird in an 89 camaro that had a 2,8l engine in it?
Backround is, i got a 88 camaro that has a broken engine for less, and I have a wrecked 91 firebird sitting in the backyard with a good engine.
Is it possible to just change the engines and ecm and it will run???
Thanks for your help, Rob
Old Apr 16, 2009 | 11:39 PM
thebufenator's Avatar
Car: Firebird - Camaro
Engine: 2.8L - 6.3L
Axle/Gears: 3.42 - 3.23
Re: 3,1 FireBird engine instead of 2,8 Camaro engine
Should be an easy swap. There will be some differences in emissions stuff, but I think thats it.
Old Apr 17, 2009 | 07:19 AM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Should be the easiest swap possible (minus another 2.8).
Old Apr 17, 2009 | 07:46 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Just take all the externals off the 2.8, put em on the 3.1, drop it in, and your off n running. Literally is that easy.
Old Apr 17, 2009 | 09:33 AM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
great, that was what I wanted to hear
Old Apr 17, 2009 | 09:36 AM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
everytime i pull a motor and swap it, at the very least i put an oil pump in it. cheap insurance.
Old Apr 17, 2009 | 04:36 PM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
sloick, can you explain that to me? don´t know what you mean.
change the old one?
Old Apr 17, 2009 | 05:32 PM
n0pre55ure's Avatar
Car: 84 Firebird / 91 Camaro
Engine: 2.8 / 3.1
Recommended to replace oil pumps if your going to disassemble a block. I did a 2.8 to a 3.1 swap replaced all seals, oil pumps, and sensors on the block it self like the oil pressure sensor, checked and replaced the timing chain.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
Linson
Aug 21, 2015 02:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
