cam swap
Old Apr 20, 2009 | 06:40 PM
thebufenator's Avatar
Car: Firebird - Camaro
Engine: 2.8L - 6.3L
Axle/Gears: 3.42 - 3.23
cam swap
So it appears I have to replace my headgaskets, and I figured a 260 cam from delta would be a good idea while the heads are off.
I was thinking that getting some LS1 or LS6 valvesprings would be a way to save some cash, anyone else done this?
If you have, what was your installed height?
Any other things I should do with the heads off? I have a timing set and water pump for the job aswell.
Old Apr 22, 2009 | 02:50 PM
Engine: 2.8L - 6.3L
Re: cam swap
So.......I find it hard to believe nobody has _any_ thoughts on this at all.......
Old Apr 22, 2009 | 04:03 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: cam swap
There are a lot of people that put those springs on the FWD heads...but Ive never heard of someone putting them on the iron heads. Not even sure if they would fit right.
Old Apr 22, 2009 | 05:08 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
Re: cam swap
only one way to find out.
Old Apr 22, 2009 | 10:43 PM
Engine: 2.8L - 6.3L
Re: cam swap
Anybody have spring recomendations for a 260 cam with Iron heads then?
Old Apr 23, 2009 | 07:07 AM
project89's Avatar
Re: cam swap
i belive the part number would be a comp cams 916 spring for the 2609 cam but id have to dbl check for ya
anesthes
Mar 10, 2016 10:35 PM
beastin91rs
Oct 9, 2015 07:38 AM
Cameeeero
Sep 18, 2015 04:00 PM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
