will a V8 MAF work with the LB8?
Old Apr 24, 2009 | 05:44 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
got a intermittant hesitation at part throttle and was thinking the MAf may be the culprit. wanted to swap a known good MAF onto the car to verify/disprove this, but the MAF is from a 88' 350 GTA. are the V6 and V8 MAFs the same or will this not work?
Old Apr 24, 2009 | 08:58 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
Re: will a V8 MAF work with the LB8?
not the same. do you have a check engine light?
Old Apr 24, 2009 | 10:08 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
actually i think they are... i "think", so don't take my word for it completely..
Old Apr 25, 2009 | 06:43 AM
sloick's Avatar
Car: Many
Engine: Several
2.8
Cardone Reman / Mass Air Flow Sensor
Part Number: 74-7557
Price:$54.99
Core: $10.00
Total:$64.99 Warranty:
1 YR
V8
Part Number: 74-4712
Price:$149.99
Core: $80.00
Total:$229.99 Warranty:
1 YR
not the same part number.
Old Apr 25, 2009 | 08:34 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
I've heard of people doing it but I think it will richen the engine up due to the v8 pulling more air across the sensor than a v6 would .
Old Apr 25, 2009 | 10:04 AM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
i have gotten a check engine light, but havent scanned the code yet. the light only came on when i was backing up into a parking spot, so its more than likely low IAC counts or something
ill have to check it with my scan tool and see
Old Apr 25, 2009 | 01:21 PM
sloick's Avatar
Car: Many
Engine: Several
you dont need a scan tool.
Old Apr 25, 2009 | 05:03 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
i suppose i could use the old "paper clip trick" to check trouble codes, but i think hooking up my scan tool would be quicker and easier
Old Apr 26, 2009 | 02:51 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
They're not anywhere close. The v6 maf is a frequency film (digital) maf and the v8 maf is a hotwire (analog) maf that requires a whole wiring change to add in the extra realys to run it.
Old Apr 30, 2009 | 03:36 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Not to mention swapping to an ECU that will support MAF readings in changes in voltage rather than changes in signal frequency. The burn-off relay is the least of the problems.
If someone were feeling particularly stubborn, though, one could probably program a small pic microcontroller to perform the translation. I'd love to see that one done.
specialized
Jun 18, 2022 09:26 AM
86IROC112
Sep 7, 2015 01:37 PM
Logan Bryant
Aug 27, 2015 11:52 AM
NBrehm
Aug 25, 2015 11:49 PM
perZ
Aug 15, 2015 01:17 PM
