does your cruise control work?
Old Apr 30, 2009 | 12:28 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
this is my 3rd third gen and none of the others worked. i was wondering in anyone else has any luck?
Old Apr 30, 2009 | 03:07 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: does your cruise control work?
Mine doesn't work. Dont know why and dont much care, but would be nice to have sometimes.
Old Apr 30, 2009 | 03:12 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
mines busted to would be nice if it worked but oh well. im probably gonna rip it out anyway like i did with the ac that didn't work
Old Apr 30, 2009 | 03:28 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
Yeah, bought mine and doesn't work, same with the a/c. going to pull them when I get the chance to.
Old Apr 30, 2009 | 03:29 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Well I haven't had my car long but I never even tried the cruise until I was on the way home buying it. I thought I would give it a try and to my amazment...it works and works well. I was really surprised. I think there is a sponsor on here who sells parts for cruise controls. I may be wrong though. Sorry for the long answer. I could have just said "Mine works"
Old Apr 30, 2009 | 07:36 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Most of the time, the switch in the turn signal stalk goes bad, and it will cost around $60 to replace the thing. There is a tech article on this. After I repaired my switch, it worked just fine, until I took the switch panel out.
Old Apr 30, 2009 | 07:37 PM
7SEALS's Avatar
mine works, but is kinda goofy. You gotta hold the switch for a couple of seconds for it to kick on. If you just press it, and let off the gas, it will pick up after you drop 7MPH or so. I just keep my foot on the gas while I wait for it to kick on, but after its on it works great from there.
Old Apr 30, 2009 | 08:14 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Mine works 100% perfect. Make sure that the vacuum vent line on the brake switch is connected and holds vacuum, that's a common problem. Also make sure that all of the vacuum feed lines to the orb of power and cruise control servo are good. The line tends to deteriorate at the orb of power and that will cause in-op cruise control too.
Old Apr 30, 2009 | 08:29 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
My right foot works perfect.
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Street Lethal
Aug 12, 2015 11:33 AM
Bull86
Aug 10, 2015 05:43 PM
