are there any header's out there for the 2.8
Old Jun 25, 2009 | 11:34 PM
ALH442's Avatar
Im looking for header's.The only ones i have found are the pace setters.
Ive got the typical manifold leak .And i was thinking of putting header's on when i do the repair.I would like some suggestion's on what work's the best for the money.This is my 2nd 3rd gen my first one was a 82 z28 and i loved it.this one is a v6 and im still in the learning curve of it .I dont mean to annoy anyone but im just getting my feet wet agin
Old Jun 26, 2009 | 08:55 AM
ChevyCamaro1990's Avatar
Car: Camaro RS
Engine: 3.1l v6
Re: are there any header's out there for the 2.8
pace setter headers are the only ones that are made for the v6's so if u do headers u can use them and they are great from what i have heard but if u do that the stock exhaust will not work...from what i was told
Old Jun 26, 2009 | 10:09 AM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
My link won't work.. but I am pretty sure summit has some.
Old Jun 26, 2009 | 11:01 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Yeah, summit has the pace setter headers, there 280 bucks last i looked i may be wrong.
Old Jun 26, 2009 | 11:04 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Yes I have seen them on Jeggs.
Old Jun 26, 2009 | 11:15 AM
entrig00's Avatar
Car: 91 Camaro RS
Engine: 3.1 V6
Transmission: t-5
Hey I think I know the answer but just need confermation and all...
will those pace fit 3.1?
Old Jun 26, 2009 | 11:35 AM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
yes they will fit both 2.8 and 3.1...im lookin at gettin a set next month...first comes injectors then headers....only question i have now is that said above "stock exhaust wont work"....what is the problem? the y pipe or something?....i thaught i saw a kit that had the headers and y pipe with o2 sensor bung in it on jegs or summit...I already have a high flow cat and 2.5 dynomax super turbo exhaust....i just need to get headers....can anyone confirm any CORRECT part numbers and also if there are fitment problems and exactly what they are?
Old Jun 26, 2009 | 01:43 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
They will fit the 3.1, but you cant use your EGR. The EGR valves are different between the 2.8 and 3.1. You will also need to extend the o2 sensor wire when you install headers since it relocates where the o2 sensor sits on the pipe, no big deal though. When you get them, get the felpro header gaskets for the 2.8 fiero, the ones that come with the pacesetters are junk, and get locking header bolts or your gonna have bolts coming loose all the time.
Old Jun 27, 2009 | 08:36 PM
flakeh's Avatar
Car: 89 Firebird
Engine: 2.8V6
Transmission: t5
I just used loctite on mine and they stayed tight perfect. I haven't had any issues with the stock gasket, but now that you say it I might go grab some of those ones you mentioned.
Stock exhaust does not work with it I'm pretty sure. I think a pipe needs to be shortened or something along those lines.
Old Jun 27, 2009 | 08:54 PM
drdave88's Avatar
Engine: 6.0L
Not sure if the stock exhaust will work or not, I had Dynomax catback and Catco converter when i put my headers on.
as far as the header gaskets, myself and others have mentioned that they blow out easily. Yes loctite will work, i guess.
Old Jul 2, 2009 | 01:07 AM
zeb87's Avatar
Car: 1987 Chevrolet Camaro RS
Engine: 3.1 MPFI
Axle/Gears: 4.10 Posi
i just put headers on my 2.8 a few weeks ago. they bolted right up to the stock exhaust except i had to twist the y-pipe a little to get it to bolt up to the passenger side flange, nothing major.
Old Jul 20, 2009 | 05:42 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
do they seriously not come with a Y-pipe? I've got a leak in my y-pipe and I figured headers would be a good upgrade if they came w/ the y-pipe. it looked like they had a y-pipe in the picture.
Old Jul 20, 2009 | 06:07 PM
V6F1R3BRD's Avatar
Engine: 2.8 - LS1
Ya that's the same reason i plan on buying headers..
Old Jul 20, 2009 | 07:55 PM
mtwlkn122's Avatar
Engine: 3.1L, 4.7L
I swear the picture at hawks shows um with a y-pipe...not that my y-pipe is bad but i want to use my stock y-pipe to hack up when i get the money to do the turbo set up...i know they are cheaper other places...could this be the reason they are cheaper?
Old Jul 20, 2009 | 08:34 PM
yea price is my next question is price. who has it for the cheapest? I'm pretty sure they all come w/ y-pipes or none of them do, it's a kit. just my logic, but whoever finds the lowest price calls the retailer to see if the y-pipe is included. and post up the lowest price you find!
Old Jul 21, 2009 | 05:51 AM
drdave88's Avatar
Engine: 6.0L
Cant tell you about the prices, youll have to just research that, but yes they do come with a y-pipe. one left bank header, one right bank header, and a 2 piece y-pipe.
Old Jul 21, 2009 | 08:16 AM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
I had a set of edelbrock headers on my 2.8 s-10 I don't know if they make them for our cars but they bolted up good and did come with a y pipe .I got them from summit.
Old Jul 21, 2009 | 02:57 PM
musclecar201's Avatar
Car: 87 Camaro
Engine: 2.8l V6
Picking myself up some as I have a big old leak in my passenger side exhaust manifold.
http://www.google.com/products?hl=en...ders&scoring=p
prices
I'm just gonna buy mine from summit, I know they have good customer service so if something goes wrong I will be fine.
http://www.summitracing.com/parts/PSM-70-1206
Old Jul 21, 2009 | 04:25 PM
mtwlkn122's Avatar
Engine: 3.1L, 4.7L
^^make sure you also add the fiero felpro gasket and also get locking bolts like stated above!
Old Aug 18, 2009 | 03:12 PM
ked5911's Avatar
Will these fit on a 1984?
Old Aug 18, 2009 | 04:17 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
^Yes.
redformula88
Oct 14, 2015 06:08 PM
86maro_252
Oct 10, 2015 06:52 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
