'89 F-bird 2.8 to 3.4 swap help.
Old Jul 4, 2009 | 11:23 PM
deadlew's Avatar
Car: '89 Firebird
Engine: 3.4 V-6
Transmission: 4spd Auto
Axle/Gears: 10b, 3.42's, Auburn LS, 28 alloys
Looking for a few suggestions. Swapped in a 3.4 inplace of the 2.8. Got everything reassembled and it doesn't fire. Sprayed carb cleaner down the intake and it fires. Checked the fuel pressure and it is 42 psi. Checked the 3.4 injectors and they are all 12.6 ohms.
Just looking for a few suggestions of where to go next. Thanks in advance.
PaulC
Old Jul 4, 2009 | 11:57 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Re: '89 F-bird 2.8 to 3.4 swap help.
Timing correct?
Old Jul 5, 2009 | 07:30 AM
deadlew's Avatar
Car: '89 Firebird
Engine: 3.4 V-6
It will run if I spray enough starter fluid down the intake. Thanks for the reply.
PaulC
Old Jul 5, 2009 | 08:42 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Are your injectors fireing when you crank it if not you wont get fuel for the engine to run . Double check your wireing and make sure everything is hooked up and tight at all connections .
Old Jul 5, 2009 | 04:42 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
cold start injector?
Old Jul 5, 2009 | 05:15 PM
xsupermann69x's Avatar
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Transmission: automatic
did u have to change your trans out of ur car to something different or was ur 2.8 trans able to bolt up to ur 3.4?
Old Jul 5, 2009 | 08:20 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Mine has done similar twice and I just had to let it sit a few days then it started fine. Plenty of fuel and spark and run on either but no run.
Also each time it was after having computer battery n all junk unhooked then back.
Old Jul 6, 2009 | 07:32 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
What injectors are you running , what intake settup , and is everything plugged up and tight ?
Old Jul 30, 2009 | 07:33 PM
deadlew's Avatar
Car: '89 Firebird
Engine: 3.4 V-6
Finally got back to working on the F-bird. Here is what I got:
Ran fine before 3.4 swap. Prior owner bypassed the ignition switch with a push button on the dash, but key has to be in the run position.
-Swapped in '95 3.4 and fuel injectors.
-Has correct fuel pressure.
-Has 11 volts going to fuel injectors, and power going to the ECM.
-Motor turns over but doesn't fire.
-If I spary carb cleaner down the intake manifold and then start it, it will run until the carb cleaner is burned up.
-Security light is lit when key is turned on.
-Checked wiring connections that were disconnected during the swap.
Starting to wonder if it has something to do with the ECM or security stuff. Thanks in advance for the help.
Yes the stock tranny bolted up to the 3.4 motor.
PaulC
Old Jul 30, 2009 | 08:24 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
How long has the tank sat? Crappy gas....?
When it runs on the carb cleaner, does it sound alright?
Old Jul 30, 2009 | 09:22 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
IIRC the security light should come on for about 3 seconds when the key turns on. if not I can tell you how to bypass VATS.
Old Jul 31, 2009 | 10:30 AM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
^^Yup sounds like a vats problem. The security feature is cutting off fuel to the motor so you cant start it...bypass the VATS and see if that works.
Old Aug 1, 2009 | 03:30 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
If you have good fuel pressure, how is the fuel pump being cut off? or do you meant the injector pulse width is shut off?
Anyway, you need a "noid" light. It's a little special light bulb that plugs into the injector plug and then when you crank it you should see the light flashing. If it doesn't flash then your injectors are not pulsating, and then no fuel. You can get this light from the auto parts store or make one from soldering wires to an old 1157 light bulb.
Let us know what you find out.
Old Aug 2, 2009 | 06:34 PM
firstfirebird's Avatar
I agree. Look up "VATS bypass", it's been covered a lot of times here. Just need a simple multi-meter.
Old Aug 13, 2009 | 07:34 PM
deadlew's Avatar
Car: '89 Firebird
Engine: 3.4 V-6
All right. Finally after:
-Checking wiring, fuel pressure, injector resistance, power to the injectors and computer, and getting a key that wasn't screwed up I took the plunge and ordered a set of rebuilt injectors.
It runs good now. They looked a little dirty but now some little things and I can drive it. Thanks for all the replies.
PaulC
Old Aug 13, 2009 | 09:47 PM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
Are you using the 2.8 injectors, and if so how old are they... my modded 3.4 wouldnt start with the 2.8 injectors with out the carb spray and I had to upgrade to 19lbers. I think the 2.8s are 15lbs. Not 100% on that tho.
Edit::: Just reread post about 3.4 injectors. Scratch idea
Cleotiz
Jan 6, 2018 08:56 PM
E Rod
Aug 28, 2015 05:17 AM
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
86Base
Aug 8, 2015 01:34 PM
92projectcamaro
Aug 6, 2015 01:20 PM
