random smoke
Car: 1991 Camaro RS
Engine: 3.1L
Axle/Gears: 10 bolt 3.23
random smoke
so after letting my car warm up i smell a light light trace of smoke and go to check and i see it coming from around distributor and possibly below it (it was very light not easy to see) are there any parts below that area that would smoke if there really old. I only start my car about once biweekly, i didnt have any time to check it out today but tomorrow after my class ill put it on my ramps to see if it is hopefully just oil that leaked on the exhaust because i just did a oil change about 2 months ago.
any ideas what it could be?
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: random smoke
Rightbehind there is where the exhaust goes from the drivers side manifold. Could be something just dripped on it.. beat to check these things out though.
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: random smoke
You could have a bad head gasket that's leaking externally onto the exhaust. When you look at see if you can see any signs of coolant. If it is coolant it could also be your heater core or hoses. Does the smoke have a smell to it?
Alex
Alex
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Re: random smoke
Lets not forget about the rear cam cover back there. I had that same issue leaking a lil oil before till I replaced it.
Car: 1991 Camaro RS
Engine: 3.1L
Re: random smoke
ok so Wednesday or thursday ill have time to check but the smoke did have a slight smell to it, but not a coolant smell. Man hopefully it will last a decent amount of time its not a DD i just start it up acouple times a month, i want to be able to get a to a shop for sfc's and i dont have the big tools if its rear cam cover
. Then later a new/rebuilt engine .
. Then later a new/rebuilt engine . Thread
