3.1 starts then dies
Old Sep 24, 2009 | 06:29 PM
punked69's Avatar
I bought a 91 firebird with a fuel injected 3.1L in it. The car had been sitting for about a year. The car starts up for about 3-4 sec. then dies the idle is rough for those few sec's. I have replaced the fuel pump, fuel filter, MAP sensor, drained and changed the fuel, checked the fuel pressure it is at about 43, and it isnt throwing any codes. If you spray starter fluid in the intake it will stay running, but take it away and it dies. Any help on this would be greatly appreciated.
Old Sep 24, 2009 | 07:23 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: 3.1 starts then dies
sounds like injector issue.
Old Sep 24, 2009 | 08:15 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Inlet screens on the injectors are probably clogged with gummed fuel. I'd also change the plugs and wires and make sure no mice or anything chewed on the wiring.
Old Sep 25, 2009 | 05:56 AM
tman1753's Avatar
Car: 1991 RS
Transmission: 350 turbo
Definitely sound like injectors. I have a set of 6 injectors that I tested with my ohm scale and came back good. One of the 6 is brand new (with receipt) 3 of them are original GM. If interested email me I'm getting rid of them CHEAP. yeargin@live.com. Most likely you will have only one or two that need replacing but worth while getting a whole set and keeping some spares.
Old Sep 26, 2009 | 12:00 PM
punked69's Avatar
Thanks for the input I'm trying to get ahold of a muiltimeter so I can test the injectors. I'll keep you guys posted on what happens.
I also found tha the oil pressure switch was bad but it still didn't make but a little difference when replaced.
Old Sep 26, 2009 | 12:20 PM
Engine: 2.7L V6
Axle/Gears: 4.41
How cheap? I just bought a set a couple of months ago with a rail that 5 out of the set seem to either be clogged or just FUBARed.
Old Oct 1, 2009 | 10:49 PM
sheppard571's Avatar
Car: 1990 Camaro
Engine: 3.1L
Transmission: Automatic
I have a similar problem but mine starts up fine and runs great, but when it warms up and i turn it off it wont start again.. it has a brand new fuel pump and filter, plug wires, distributor, rotor button, ignition coil, IAC vavle, and TPS, i had the ignition module tested at two different stores and both said its good, and now im out of ideas
Old Oct 1, 2009 | 10:59 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
OMG!, We have been going through the samething but all fixed now!!! PLEASE try this thread...
https://www.thirdgen.org/forums/tech...art-story.html
Old Oct 1, 2009 | 11:03 PM
Car: 87 T-Top GTA
I know its alot of reading, alot of GOOD info, I got a good feeling that the answer to your problem can be found there!
Old Oct 1, 2009 | 11:06 PM
Car: 87 T-Top GTA
punked69, try to start the car with the MAF sensor Disconnected and see what happens.
Old Oct 2, 2009 | 05:26 AM
Engine: 2.7L V6
Axle/Gears: 4.41
91's don't have a MAF sensor. I'm thinking some sort of vacuum leak. Either that, or, like I said above, the fuel injectors are gummed up and it's running VERY lean (which is BAD for the engine, BTW).
:edit: Now that I read through the other thread in the link above, it is possible that the pickup coil (yes, that is what it's called, and yes, it is a Hall-effect sensor) is going bad. These things are in excess of 15 years old now, and things do wear out. I think I'm going to have to do mine as well.
Reminds me of a saying there is in my missing Automotive Electrical and Electronics Systems textbook, and what a senior GM tech told me about 5 years ago: "No spark, no squirt. If you have no fuel delivery, check to see if you have spark."
Keep in mind that the ignition module is just a go-between for the ECM, the ignition coil, and the pickup coil. If the pickup coil is bad, the ignition module may seem to be bad because the ECM isn't receiving a reference pulse (which is why one of the steps in the "No Spark" flowchart is to check the signal from the PU coil). If the wire between the ignition coil and the dizzy is bad, the module won't receive power.
Next time the engine has this trouble, check to see if you have spark as well. If the PU coil is bad, you have 2 choices: Remove the dizzy and spend a day rebuilding it and replace the coil for $15, or replace the entire thing for $250.
Old Oct 2, 2009 | 07:53 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
The car starts up for about 3-4 sec. then dies the idle is rough for those few sec's. If you spray starter fluid in the intake it will stay running, but take it away and it dies....
Check your TPS voltage, and IAC counts....
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
EFR2000
Aug 18, 2015 08:54 PM
