3.1 v6 what can I remove???
Old Sep 27, 2009 | 10:47 PM
rustbucket29's Avatar
Hi, I am new to this, I just bought a clunker 92 camaro v6 auto, and I'm planning on using the motor and tranny in a '58 nash metropolitan. I want to use all the fuel injection, but I want to strip as much of the smog and ugly bs stuff that I can, but I'm not that familiar with fuel injection or smog. I'm sure I can ditch the smog pump, but what about stuff like egr valve? does the computer need this to run correctly? Basically all I want is the bare bones componets that the system needs to run correctly. Any ideas?? I appreciate anyones help. Tom
Old Sep 28, 2009 | 08:04 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 3.1 v6 what can I remove???
If the ECM remains stock then the EGR should stay. However, you will need to also get a VATs delete box, as the ECM needs that before it will fire the injectors. {edit: can also use the VATs system that is in the '92}
So your best bet is to get what is required to burn a PROM and make some changes to the calibration. Turn off VATs, set the EGR enable temperature high, set the AIR system enable temperature high, disable the cat-con protection (set the trip points high), and burn a chip.
See moates.net for a Burn2, G1 adapter, and a couple of chips.
If you retain the serpentine set up and dump the smog pump (AIR system), look for an 88 - 89 camaro/firebird with an auto. In one or both of those years the auto equiped cars didn't use a smog pump. They have an idler assembly in place on it.
Get one of those and install it. Note that a different belt is required. The same one that is on that car is the proper one. The idler prevents the long section of belt from flapping around.
RBob.
Elephantismo
Feb 13, 2019 12:51 AM
Lex87
Mar 13, 2006 11:38 AM
mm68
Jul 30, 2003 04:34 PM
82-T/A [Work]
Jun 10, 2003 05:07 PM
a*jones
Oct 17, 2000 08:48 PM
