code 45
Old Oct 5, 2009 | 01:26 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
code 45
getting a code 45 for rich o2.
have new injectors to install tomarrow.. been raining here to much in the last week.
gonna check the fpr also and have a new o2 to install.
any thing else i should check ?
Old Oct 5, 2009 | 06:55 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: code 45
Do you ever 'top off' the tank? Fuel will back up into the evap canister.
Old Oct 5, 2009 | 11:31 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
Re: code 45
canister is not hooked up.
Old Oct 6, 2009 | 09:57 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: code 45
Exhaust leaks will play havoc with the system as well.
Old Oct 6, 2009 | 03:57 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
Re: code 45
installed the new injectors. no leaks runs great. exhaust don't smell rich any more.
i think i need to check out the cat though. got a replacement just need to install.
using these injectors
http://fuelinjectorconnection.com/sh...&productId=186
Old Oct 6, 2009 | 06:35 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
Re: code 45
just got back from getting my cat out of my storage shed.. low and behold on the way 30 mile trip btw... the code 45 came back after 15 miles of driving.
cat changing on thursday.. along with o2.. i hope that fixes it.
Old Oct 6, 2009 | 10:01 PM
bl85c's Avatar
Car: '85 maro
Re: code 45
What else is going on? Throwing parts at it isn't the way to fix it. Do you have a fuel pressure guage?
Old Oct 6, 2009 | 10:21 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
Re: code 45
checking fuel pressure on thursday.
Old Oct 8, 2009 | 09:09 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
Re: code 45
fixed it. timing was off 2 degrees.
Old Oct 17, 2009 | 02:37 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
Re: code 45
it came back on after a 60 mile trip. only throws a code above 75-85 mph.
Old Oct 27, 2009 | 03:23 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
Re: code 45
how do you check for a leaking fuel pressure regulator?
Old Oct 27, 2009 | 09:05 PM
bl85c's Avatar
Car: '85 maro
Re: code 45
Whoa hold on a minute, this is what the injectors you're using look like? Wish I would've taken a look at these at the start, they're not correct. These are intended for later motors and won't run correctly. Get a refund and make sure they know to change their application info on their website to specify 3100.
Old Oct 27, 2009 | 11:58 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
Re: code 45
i callled the guy and asked first before i even ordered them. car runs good other than i can't get the code 45 to go away. and i had it before i even did the injector swap.
are the injectors to big then?
Old Oct 28, 2009 | 09:07 PM
bl85c's Avatar
Car: '85 maro
Re: code 45
No, they're just the wrong design if those are the injectors you're using. Different resistance & not compatible with early stuff. You had it before the swap though? What was your fuel psi?
Old Apr 21, 2011 | 12:03 PM
86 Camaro joe's Avatar
Car: Camaro
Engine: 2.8 tune port
Re: code 45
I recently got code 45,
but you where saying if you top off you
gas tank gas can get into the evap canister ?
this can cause code 45?
cause i normally top off my tank,
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
