Trans question
Old Oct 12, 2009 | 12:05 PM
92-RS-V6's Avatar
Car: 1991 RS V6
Engine: 3.1L V6
Axle/Gears: I have no idea...
Trans question
Hi all
I have a question about my transmission (700R4?). When I'm cruising on the highway about 60 or so mph, and I go to gently accelerate, the RPM's rise a little for a short while (half a sec) and then settle down again. Almost as if there is a short slip.
Is this normal operation or a sign of excessive wear?
Many thanks
Matthew
Old Oct 12, 2009 | 12:49 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
Re: Trans question
Does this happen only if you let off a lil then get back on it?
Sounds like its just your converter unlocking then locking. This is normal.
Old Oct 13, 2009 | 03:35 PM
92-RS-V6's Avatar
Car: 1991 RS V6
Engine: 3.1L V6
Re: Trans question
Yeah pretty much. Thanks for clearing that one up. Always paranoid about trans problems...
To save starting another thread I have an exhaust question. Forgive my ignorance but why is my V6 so damn loud? I'm sure when I saw it around before I bought it, it was much quiter. There is some slight corrosion coming through on the welded seam on the rear silencer. Could it have collapsed internally?
Cheers, Matthew
Old Oct 13, 2009 | 04:03 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: Trans question
could be a hole on top of the muffler.
Old Oct 14, 2009 | 03:43 PM
92-RS-V6's Avatar
Car: 1991 RS V6
Engine: 3.1L V6
Re: Trans question
I took a look... looks like my muffler has rotted from the inside. Got a replacement on the way
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
