V6 Carnage picture thread
Old Nov 5, 2009 | 09:15 PM
project89's Avatar
just for fun lets post up crap u have blown up in ur v6 powered f-body
ill start with this
shattered flexplate after installing my turbo
i'll have to dig out the pictures of my old toasted 2.8 as well
post up what u got
Old Nov 5, 2009 | 10:32 PM
transamrob86's Avatar
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
Re: V6 Carnage picture thread
Blew both head gaskets and spun a main and rod bearing..........
Old Nov 5, 2009 | 10:44 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
OMG what is all that stuff in the engine?
Old Nov 5, 2009 | 10:52 PM
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
That is what you would call dried sludge. The guy before me used cheap oil (probably quakerjunk) and it just gummed up over time.
Old Nov 5, 2009 | 11:01 PM
Car: 1992 firebird
Engine: V6
HOLY **** but that crazy it's like wet cement oo man that poor motor
Old Nov 5, 2009 | 11:25 PM
project89's Avatar
thats what happenes when u dont change ur oil when ur supposed to,
lol so remember what the inside of that motor looks liek when u want to put off ur oil changes
Old Nov 5, 2009 | 11:28 PM
project89's Avatar
this is my motor with over 200k miles on it
the rust in the cyls is form me removing the one head off the motor and it being outside for 2 weeks, motor was being pulled anyway.
^^ beat the living **** out of that motor but it looks great on the inside
changed the oil every 1,500-2k miles and used castrol 20-40 or castrol straight 50 wieght
Old Nov 6, 2009 | 08:57 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
This is what happens when your car:
1. Has no air dam and is primarily driven during the hot summer months.
2. Has not had the oil changed in a while before new owner decides to take care of it.
3. Had the oil changed with wrong weight (oops!) because there were no indicators as to what weight oil went into the engine.
4. Has had a tiny bolt nobody has seen before dropped into the #6 cylinder.
This was the #4 piston in my 2.8 back in '04. The engine had been on its way out for a while as a result of constant overheating due to PO knocking/removing 99% of the front air dam off, and tons of crap (but not anywhere near as much as in the pic above) in the lifter valley. When the engine blew, I ran it for 3 seconds before finding out what the HEAVY knocking noise was. Too bad I don't have a pic of the block and oil pan... This bugger blew a 1" x 2.5" hole in the lower edge of the block and oil pan, knocking out the dipstick tube mount. I still have the dipstick and tube as well, along with the lifters I removed. Wish I had kept the pass side exhaust manifold and cylinder heads, though.
:edit: Forgot to mention this was sticking 1/8" out of the cylinder and the crank was locked up tight until this was removed. You may not be able to tell in the pic, but some parts of the piston skirt are missing as well. Don't know where the other piece of the con rod went, though... I had 3 pieces in the garage as keepers, and left the other in the oil pan.
Old Nov 21, 2009 | 06:19 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Here's what detonation will do...
sorry that they're a little fuzzy. took them with my phone
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
Thornburg
Aug 27, 2015 08:28 PM
chubsworth
Aug 26, 2015 02:34 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
Linson
Aug 21, 2015 02:12 PM
