Car takes several tries before it turns over?
Old Dec 4, 2009 | 05:24 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Just tackling little gremlins with the 91 I bought, seems that when you get in the car, turn the key it will just make a clicking sound, then after several tries (guy I bought it from said it helps when you put the car in N and then put it in gear and try and start it)
I try starting the car several times without it firing, then after several times, it will start right up. Is this some sort of a starter/flywheel issue or something else? Battery is charged, this was my first thought since it was sitting for 2 years but I put it on the charger and still doing this, also with another good battery as well.
Old Dec 4, 2009 | 06:45 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Car takes several tries before it turns over?
I said this in a thread not too long ago. Check your connections between the positive battery post and the starter. Use a voltmeter and check for a voltage difference between the battery bolt and the solenoid. Anything above zero means you probably should check the positive cable. Check the starter ground point (the mounting flange) for rust, grease, and other debris.
Old Dec 4, 2009 | 11:10 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
maverick, are you intending to say to check for resistance between the battery terminal and the solenoid? check that way, you won't see any voltage.
Anyway, this sounds like the same problem I'm trying to straighten out right now, also. I have my engine out currently so I checked voltage and all while it was easy to get to. It worked flawlessly while I was checking it out. I'm afraid to say that it may be a bad wire somewhere...a wire that won't carry the voltage once a load is applied. the tricky part is finding that bad wire! My post about this is titled "need starter help". I'll update if/when I actually find a problem.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
BrianI
Aug 9, 2015 11:52 AM
