How do these plugs look?
Old Dec 27, 2009 | 08:19 AM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I installed some new plugs yesterday hoping it might cure my sputtering problem...nope. These are in order 1-6 left to right. They had that light grey primer look and I was wondering if this is normal. I checked to rotor cap and dizzy also to cure the sputtering but no luck. I'm thinking my injectors are the cause of my sputtering and rich woes. Should I go with reman injectors to see if that clears it up? I'm also thinking the reason my CCP isn't cycling on is BECAUSE of the rich condition and the ecm sees to much fuel and not turning on the CCP solenoid because the mixture is too rich.
Ken
Old Dec 27, 2009 | 04:06 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: How do these plugs look?
Plugs look good, even for the continued coding. Which means you have other problems, because they aren't black, which WOULD mean you're running rich.
Like I told you before, you have a fault in the canister purge system. The solenoid is supposed to be ON most of the time, and OFF when purging is desired by the ECM. Turning the solenoid ON stops the canister from purging, not the other way around.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
