speedometer?? anyone wunna help me out.
Old Mar 27, 2010 | 10:30 AM
Xx89CamaroRSxX's Avatar
i was in the process of doing that led swap and now i have no idea how to get the damn speedometer cable plugged back in so now i have no idea how fast im going >_< i know theres gotta be a process of doing this but i cant figure it out.
i searched and couldnt find anything apparently im the only idiot who doesnt know how.
i had this on the powertrain and tranny board but no help so maybe you guys can
thankss
Old Mar 27, 2010 | 10:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedometer?? anyone wunna help me out.
Originally Posted by Xx89CamaroRSxX
i was in the process of doing that led swap and now i have no idea how to get the damn speedometer cable plugged back in....
Put the cluster back in place, then grab the cable and push it onto the speedo head until it snaps into place. The clip can be seen in the following pic:
https://www.thirdgen.org/forums/atta...s-spdoclip.jpg
Here's are some pics that may be more helpful:
https://www.thirdgen.org/forums/inte...al-speedo.html
The metal housing goes over the speedo head and the ridge on it seats under the clip seen later in that link and above in the my first link.
JamesC
Old Mar 27, 2010 | 10:46 AM
JamesC
is ther something i should have removed to be able to do this? i cant get my hand back ther to get it to snap on. the only thing i was able to do was to get the cable to sit on the thing but ony that didnt make the speedometer work.
just so you know i have everything still attached. the dash the steering wheel only stuff i took of was the stuff to pull the gauges out enough to replace the bulbs. i never really took it COMPLETLY off
and btw i was just curious do the colors of the bulb holders mean anything? sum green some black etc? jw
Old Mar 27, 2010 | 10:54 AM
JamesC's Avatar
Remove the kick panel beneath the dash, lay on your back and look up. Locate the cable and push it on.
If you look closely on the bulbs, you'll note that some are 164 and some 194. IIRC, the green are 194, the black 164.
JamesC
Old Mar 27, 2010 | 10:58 AM
JamesC
alright ill try this in a little. thanks for the help. if i have any problems ill let you know. i was reading things on google and thought i was going to have to detach it from the tranny or where ever.
lets hope it works.
Old Mar 28, 2010 | 11:45 PM
aviator84's Avatar
In the back of the speedometer there is a small metal spring clip that actually catches the cable and holds it in place. Is the spring clip intact on yours? You should have had to push it in to remove the cluster. The first time I removed mine I thought it was stuck and tugged on it, breaking the clip.
edit: Also, make sure the metal end on the shield of the speedo cable is tight, on my brothers car the metal end seperated from the shield and his speedo stopped working.
Old Mar 29, 2010 | 04:27 PM
i was able to get it in after james c gave me the info. thanks guys for the help it was easier then i thought!
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
mattcanty
Oct 12, 2015 11:08 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
