serious intake question... or how i hate aluminum intakes
Old Mar 30, 2010 | 12:18 AM
DemonKnightDK's Avatar
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
Okay, heres the deal. I was putting my intake back together so I can get my engine back in the car, ect... any ways long story short,the front bolt hole on the passenger side (closest to the front of the car) as I'm tighting down the bold the lower part crumbles off!! SOB! now every other bolt is fine and tight just like it should be, can I run like this?
my wife will throw a gasket if I have to say i've gotta wait on another new part... we just sold our second car to pay for my firebirds resurrection... (it was her first car.. so yea..)
also i noticed that my injectors tips has a small crack in the rubber surround, the o ring, the part right around the very tip should that be an issue? I'm trying to just get the thing on the road again... why couldnt they have just used steel? paint it or powder coat it so it dont rust but why aluminum?!
Old Mar 30, 2010 | 08:51 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: serious intake question... or how i hate aluminum intakes
The injector I don't think will matter, but hard to say especially without seeing it. as for the intake manifold, same deal, hard to say without seeing it, but as long as there isn't a vacuum leak because it then it should be ok, also you could try JB welding the piece the broke off back on there. And I'm amazed it did that to begin with...I really don't see what could degrade the integrity of it to do something like that, I could hit mine with a hammer and it wouldn't phase it.
Old Mar 30, 2010 | 12:14 PM
Car: 1985 Firebird
beats the hell out of me, as i was doing was tightening the bolt down and it got really loose, so I looked at it and the lower part was dust... there aint nothing left to jb weld back on lol.it seems like the other screws are doing most of the clamping pressure so I think it'll be okay.
I got the belt routed last night as well as the starter put back on, I just need to get an oil filler cap and some random bolts and slap the plugs and wires back in and I should be golden.
Old Mar 30, 2010 | 04:25 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
If you end up needing a new intake pm me I've got an extra one
Old Mar 31, 2010 | 12:49 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The rubber o-rings should be replaced any time you take the injectors out. If they are cracked, then double yes on replacing them, it will cause a vac leak.
As to why alumn intakes? Heat soak, weight issues, easier to mold, machine. For modding reasons, easier to port as well.
Go look at a ford 5.4l truck motor, the whole intake is plastic.
Old Mar 31, 2010 | 01:37 PM
Engine: 3.8, 3.4
My mom's 2.4 dohc in her grand am has a plastic intake manifold too.
Old Mar 31, 2010 | 08:01 PM
Car: 1985 Firebird
the o-rings them selves were not cracked it was the very tip surrounding the injector opening. (I just put it all back together do I really have to redo those o-rings?)
Old Mar 31, 2010 | 08:03 PM
Engine: 3.8, 3.4
While were on the subject, I got the O rings at the top of the injectors(top as looking at them installed) but the others are proving difficult to remove-suggestions?
Old Apr 1, 2010 | 03:15 PM
Dale's Avatar
Engine: 350 S-TPI
The ones in the fuel rail? Shouldnt need to remove/replace them. But they have c-clips that need to be spun around. Then if they have never been removed, you have to yank them suckers out with about everything you got.
Old Apr 1, 2010 | 03:30 PM
Engine: 3.8, 3.4
The one's near the tips of the injectors, one is orange, the other is a lot like the one at the top.
Attached Thumbnails serious intake question... or how i hate aluminum intakes-100_0374.jpg
Old Apr 1, 2010 | 03:37 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Use oil, put one side in the groove, and roll them into place, kind of like a piston ring.
Old Apr 1, 2010 | 03:39 PM
Engine: 3.8, 3.4
Trying to remove them...getting them on is the easy part...
Old Apr 1, 2010 | 06:51 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Cut 'em off with a razor, unless you don't have new ones, in which case you'll need a pick or something to get behind them and start getting them off (kind of like a bicycle tire).
Old Apr 3, 2010 | 11:44 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
New O-rings are like $8. Just go pick them up at the AutoZone or Pep Boys. They are cheap insurance against having more problems once you get the car back together.
Old Apr 7, 2010 | 08:30 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I've always heard that the o-rings should be lubricated with petrolium jelly before installation.
Old Apr 11, 2010 | 03:15 AM
zeb87's Avatar
Car: 1987 Chevrolet Camaro RS
Engine: 3.1 MPFI
Axle/Gears: 4.10 Posi
if the plenum itself has no structural damage besides just stripped threads, use a heli-coil or time-sert
hydrolic144
Oct 4, 2015 08:23 PM
DJanes97
Sep 1, 2015 02:55 PM
hayesaw0210
Aug 23, 2015 11:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
