Air filter/ intake questions.
Old Mar 31, 2010 | 08:31 PM
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
Is this the only way the stock 87 got air? holy crap.
Next, is replacing my MAF sensor a good call?
Finally, what is this? (where my finger is pointing) At first i thought it was a sensor, but now it looks like it just sucks air.
Old Mar 31, 2010 | 11:22 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Air filter/ intake questions.
If memory serves that goes to your PCV valve, which vents crankcase pressure(it vents back into the intake manifold where it is mixed with new air) buildup caused by blowby, which is combustion chamber gases that slip by the piston rings
Edit: if that hose goes to your valve cover that will verify that it is the PCV valve line
Also I've seen worse intakes than that, but I've seen better too, like my dual snorkel, best non ram air, stock intake setup ever,lol.
Old Apr 1, 2010 | 12:17 AM
DemonKnightDK's Avatar
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
i dont remember that on my 2.8... i hope its not there/needed on a 3.1 cause I dont think I remember seeing it or compensating for it in my new intake tube..
Old Apr 1, 2010 | 12:20 AM
Engine: 3.8, 3.4
It might have a valve cover breather instead, same function, minus the dumping oil into your intake manifold part
Old Apr 1, 2010 | 12:45 AM
project89's Avatar
the hose in the pics ur pointing at in the intake tube is a breather and is not hooked to the pcv valve, basically its for when u fo wide open and there is zero vacum it sucks air out of the valvecover by using the ait flowing past the tube to suck air out. on an old smallblock chevy or what not it would be the same as having a pcv valve in one valve cover and a breather in the other side
Old Apr 1, 2010 | 02:24 AM
Engine: 3.8, 3.4
Does having it or not having it affect performance at all? It would explain why I've noticed some race engines have two valve cover breathers, for the longest time I never even knew wth the things were, till I got into this sort of stuff big.
Old Apr 1, 2010 | 10:26 AM
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
that was one of my rain reasons asking what it was, didn't know if i had to keep it when i set up the new intake for it. I'm going with yes, not like it will be hard to do, just wondering.
I guess everyone thinks replacing the MAF is also a good call?
Old Apr 10, 2010 | 11:22 PM
mongoosekeith's Avatar
is the board in the MAF crinkled or distorted if yes REPLACE it
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
kyle5647
Aug 15, 2015 11:56 PM
TreDeClaw
Aug 14, 2015 06:58 PM
