looping idle
Old Apr 1, 2010 | 01:58 PM
aaron0991's Avatar
looping idle
What would cause the 2.8 to idle back and fourth from 2000 to 1000 rpms. The engine slowly climes to 2000 and drops to 1500 or 1000.
Old Apr 2, 2010 | 01:30 PM
aaron0991's Avatar
Re: looping idle
thin maybe ill sea foam the engine ans see what happens
Old Apr 2, 2010 | 06:34 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: looping idle
What year is the car? If it's got an adjustable TPS, the sensor may be adjusted improperly and the ECM assumes a higher idle.
Old Apr 3, 2010 | 07:23 AM
aaron0991's Avatar
Re: looping idle
its an 88, i know that the idle screw is cast so i can not adjust it
Old Apr 3, 2010 | 12:10 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: looping idle
I'm not talking about the idle speed stop screw, which CAN be adjusted after you remove the plug covering it. I'm talking about the TPS, on the other side, under the idle control motor.
Old Apr 3, 2010 | 01:08 PM
aaron0991's Avatar
Re: looping idle
I'll have to look
Old Apr 3, 2010 | 11:38 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
Re: looping idle
The readings on the TPS should be between .49 and .53 volts. If its higher or lower, you need to adjust it.
Old Apr 3, 2010 | 11:57 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: looping idle
Sounds like the IAC motor to me.. pull it out and clean the plunger and passage with some carb cleaner and a small wire brush, then disconnect the battery for a couple minutes. It should stall out on the first start, after that it'll fire up, idle high then back down slowly. Take it for a drive after that and make sure it's ok.
Old Apr 4, 2010 | 12:14 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: looping idle
.45V to .65V actually... Mine's dead on at .55VDC.
Old Apr 4, 2010 | 07:47 PM
aaron0991's Avatar
Re: looping idle
i took off the airflow sensor and the car ran good no crazy idle and no high rpms do you think i should get a new one.
Old Apr 4, 2010 | 08:03 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: looping idle
Since the sensor is off, look at the orange film inside to see if it's flat or not. If it's not flat (you can tell by shining a light on it), get a new sensor, as the one you have won't read properly with a bad film.
Old Apr 4, 2010 | 10:26 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
Re: looping idle
Yup if you took off the MAF and it runs better you probably need a new one. Like mav said, if the frequency film inside it looks like the surface of the atlantic ocean(wavy as hell), then its bad.
Old Apr 5, 2010 | 08:00 AM
aaron0991's Avatar
Re: looping idle
Ok i was just about to ask that, lol thats a nice way to put it. I took it off and it purred like a kitten. Right at 800 rpm's and amazing throttle response. Just couldnt drive it cause it sputtered and spat. The sensor is pretty wavy i'll try to take some pics of it tonight just to show you how bad it is and then its comming out.
Old Apr 5, 2010 | 10:50 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: looping idle
There was a seller on eBay selling NEW AC/Delco sensors the last time I looked. Don't get a cheapo parts store one... You could install it one month and have it fail the next (been there, done that, TWICE). I know the replacments at the parts stores MAY have a lifetime warranty, but, do you REALLY want to go through this about every year and a half or so?
:edit: Case in point, here is a pic of my latest failed MAF. Notice how the film looks like a skate ramp and isn't even in the same place on the board as the factory one, and that there is no air funnel. This was a parts store sensor with a lifetime warranty, the SECOND one I had to replace in 2 years after I put it in:
Old Apr 5, 2010 | 11:00 AM
aaron0991's Avatar
Re: looping idle
so where would i look on ebay? would i just look for 2.8 maf or third gen maf?
Old Apr 5, 2010 | 11:03 AM
aaron0991's Avatar
Re: looping idle
just looked on ebay but i cant find new ones just used part store ones.
Old Apr 5, 2010 | 06:18 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: looping idle
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
If you have a Camaro, you'll need to find a way to knock the elbow off without hurting the sensor. Hurry, there's only 20H left.
Old Apr 5, 2010 | 06:41 PM
aaron0991's Avatar
Re: looping idle
shouldnt be a problem i have a firebird
Old Apr 5, 2010 | 09:36 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
Re: looping idle
Holy crap Mav, that is bad! The film on the reman my dad bought a few years ago looks like that. I'm glad i switched to a 165 ECM and the 70mm Ford MAF. I dont have to deal with that crap anymore with the frequency MAF's
junior419
Apr 7, 2025 11:35 AM
86IROC112
Nov 27, 2015 09:54 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
