error code reader
Old Apr 5, 2010 | 09:43 AM
aaron0991's Avatar
error code reader
where can i find one for a 1988 2.8?
Old Apr 5, 2010 | 10:20 AM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
Re: error code reader
Save yourself money and use a u bent paper clip between terminal A & B or the two top right terminals if your in the driver seat. Then the SES light should flash with th ignition on (not started)
Old Apr 5, 2010 | 10:48 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Error code readers are generally nothing more than a $20 paperclip anyways, unless you're asking about a scan tool or PC link cable plus scanner software.
Old Apr 5, 2010 | 10:58 AM
aaron0991's Avatar
Thanks i'll use the paperclip to cancel out the ses code, but what about reading the code to see what the problem is?
Old Apr 5, 2010 | 11:32 AM
Stephen's Avatar
Car: 87 GTA
The paperclip won't clear codes, only disconnecting the battery will.
The paperclip allows you to read the codes. ECM Codes
While it is really no better than a paperclip, Autozone gave me one of their "fancy" keys. Just a key shaped piece of aluminum with 2 prongs to stick in. While Autozone should have one, I've found that most of today's employees have no clue how to do an OBD I car! I've had a couple of different stores hand me the "key"..."Do you know how? I don't. You can use this if you do, that's all I know."
Old Apr 5, 2010 | 11:58 AM
aaron0991's Avatar
so i would just count the number of flashes from the ses light, thats a lot of flashes.
Old Apr 5, 2010 | 12:02 PM
Stephen's Avatar
Car: 87 GTA
Yes count flashes, but it isn't "counting a lot"
Long flashes are 10s, short flashes are 1s.
Like.....Code 23 = 2 long flashes, pause, 3 short flashes.
Old Apr 5, 2010 | 02:28 PM
aaron0991's Avatar
ok so 40 would be 4 long dashes
Old Apr 5, 2010 | 02:29 PM
Stephen's Avatar
Car: 87 GTA
I don't think there is a Code 40, but you've got the right idea.
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
