what you paid on V6!?!
Car: 1991 camaro rs. 1992 camaro z28
Engine: 3.1 liters/V6. & 305 v8
Transmission: automatic
i paid $1200,
good car, runs and everything.
whats wrong with it- headlights out, fuse-box hangs out, right fender has hole, no interior roofing for t-top, 4 cracks in dash, hole in exhaust, missing front bottom fender, ttops lock broken, door locks broken...and funny thing is i dont know how to drive stick shift.
hahahaha.
but thats why i bought it so i could learn.lol
hahahaha.but thats why i bought it so i could learn.lol
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: what you paid on V6!?!
if you'r asking us what we paid, I paid $900 for a car in much better condition than that, but I think I got a heck of a deal. you don't see many v6/t5 cars come up for sale, so if that's what you want, go for it
post some pics, let us see what you came home with
here's mine
https://www.thirdgen.org/forums/memb...en-family.html
here's mine
i paid 400 for my 1990 camaro rs with the v6 the only thing wrong was it needed a paint job,two back tires,and the trunk latch assembly. im doing the rusto paint job next weekend.
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
i paid 300 for mine, and it neeed a tranny that i got for free.
But, i tore it apart anyway to make it go fast
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Just bought a 1990 Camaro V6 auto for $500.00 that needs paint.
Car: 89 RS
Engine: 2.8
I think I have seen another post similar to this somewhere in the forums. 400 for mine. Runs and drives great but it needs interior and bodywork. Plenty of rust but I have removed most of it. Its sitting in my garage waiting to be finished.
Kevin
Kevin
Car: Camaro
Engine: V6
I paid 200. Needs fuel tank and fuel sending unit but i am builting it to be a strong daily driver. So i am replacing brake lines rebuilting the gear box and master cylinder along with replacing suspension componets. so it was a good starting price.
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
$800 for an 88. No power options, no air conditioning, and t-tops.No rust, only a couple of door dings and pretty good paint. The trans is shot, but a friend of my dad's did it for the cost of the parts. Interior was really dirty, and it needs a bunch of TLC. It's my 14 year old son's first car.
Car: 1989 Pontiac Firebird
Engine: 2.8L
I got mine for FREE hahah! No one bought it for me, my Grandfather just gave me the car since he has no use for it anymore. It needed a fuel pump, gas tank, fuel pump relay. All thats done. Next is tires, brakes, paint, interior and a nice clean up. But the best part is my Grandfather said he would pay for the parts as long as I fix the car up myself
-Derick
-Derick
Car: 88 Camaro
Engine: 2.8v6
Forgot to mention that on my son's $800 car, it also had a new battery in it and a mint passenger side exhaust manifold in the back.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Paid $1k for mine and know I got ripped off. Needed paint, tires, vacuum lines, ECM, fuel injectors, had to install a cat and get rid of the "test pipe" to pass inspection along with both front brakes, also had to replace the engine crossover pipe PO somehow broke in half right where the pipes come together under the engine, both tailpipes welded to Flowmaster muffler crooked, engine died within a year (partly my fault but PO was the one who broke the air dam off of the front and caused it to overheat all the time), trans died a year after that, have one bent ARE rim I can't replace because these are hard to find (didn't get any factory rims with the car and all 4 tires were not the right size) and only got 3 center caps with these rims, interior is still crap (one lower rear seat cover torn to shreds along with the upper on the same side and the other not much better, HUGE rust stain under pass side floor mat that I can't get out, console was completely junk along with the radio pod, dash was cracked, most has been replaced with the exception of the front seats and carpet), leaking weatherstripping, hatch pulldown was broke and hatch was left partly open, has a crappily replaced pass side quarter panel, both fenders were replaced along with both bumper covers and the pass side fender still has a monster dent in it, driver's door inner panel cracked due to window motor, driver's mirror was missing the control stick (don't ask why as I still don't know). And the icing on the cake... The lock rod for the pass side door was INSIDE the door panel when I bought the car, meaning the pass door didn't lock. And I could easily turn the ignition lock WITHOUT the key, which was very badly worn to the point it only had one bump left on it.
Seatbelt recall was never performed, either. And both front receiver guide/cover things were cracked and broken. And haven't been replaced.
But I did get a relatively new battery, starter, and, supposedly, a fuel pump! GTA door panels are in sad shape, however.
Car: 88 Camaro
Engine: 2.8v6
I was told the pass manifold was cracked so I pulled it to put the replacement on, turns out 4 bolts were broken. The pass ones I have both have the EGR mount. I think I want to hang onto my spare for now. Mav, I started a thread for this car last night. Its running rough and i'm looking for some advice. Its under rough running 2.8
Engine: 2.7L V6
Axle/Gears: 4.41
Just posted there.
Really wish I could find one of those manifolds, though. Been looking for a while and can't find one without the AIR bung...
As that's the major thing that keeps coming loose and creating a leak
. Member
Car: 87 Buick Regal T
Axle/Gears: 2.56 blah
I gave $525 for my 89 V6/T5 Firebird and If I can ever get the thing to run right with the tired 2.8 again I will swap a 3.4 in it and use it as a daily.
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
I paid 500$ for my V6 and 350$ later it was inspected.
Car: 1986 camaro v6
Engine: soon to be 305
Axle/Gears: someone please tell me
I traded a astro rs for mine that I had gotten for free and had put 10,000 miles on in six months before the headgasket puked and I traded it for the camaro that needs a new tranny rust removal floor pan repair paint engine work and tires and brake work.... I think I traded up, LOL
Engine: Multiport 2.8L V6
Transmission: 700r4 with Shiftkit
Axle/Gears: All Stock
Speaking of Free cars, I talked to a friend who has an 87 or 88 Camaro rs and he was gonna scrap it,but I told him I'll take it.Thats another good come up.
I'll take pics of it next time I go over, it needs a few parts like tail lights and a wheel in the driver rear(Its sitting on a spare tire,) the only thing it needs is a Battery and gas.
Car: 92 Pontiac Firebird
Engine: 3.1L FI
Transmission: Borg Warner T5
Axle/Gears: Stock 3.42
I paid $300 dollars for a 92 Firebird 3.1/T5. The engine had a spun rod bearing, but I got a complete motor with the deal. It was originally a PA car. The only thing it needs now is tires, brakes, and a driver side fender because someone didn't know how to use a car dolly.
Car: 86 camaro berlinetta
Engine: 2.8, soon to be 3.4 w/ turbo plans
Transmission: 700r4(rebuilt in jan. '10
Axle/Gears: stock 3.23 open
i picked up my '86 berlinetta 2.8 t-top for 700 bucks. someone had it sitting in the yard for 4 years. didn't even transfer the title from the sale 4 years ago.
not the prettiest. needed front suspension rebuild, and tranny only made it another 6k miles before i had to rebuild.
this is what it looks like after about 1200 dollars in parts.not too bad
Car: 1986 camaro v6
what company made the wheels on your car?? I have the same wheels on mine and I want/need center caps as mine dont have any and somebody spray painted them red so I really need to strip and refinish them, I never saw those wheels until I got my car then I saw them all over the place on third gens
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
paid $500 for mine, but it needed a radiator, ac condenser, driveshaft, windsheild, and a headliner
about $1000 later it needs a headliner and gas lol
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
2,799 for my 89 rs, typical gm seperated clearcoat, interior almost mint aside from a rip on driver side seat and cracked dash, ran great when i got it almost 2 years ago and still runs great
Car: 1991 Camaro RS
Engine: 3.1L
Axle/Gears: 10 bolt 3.23
2k looks just like juggaloron's but green rs trim even same rims with 235/60r15, good interior just dirty carpet from daily driver use from previous owner, and crack in the dash and i think had 150k miles when i got it & runs fine.
Car: 85 Camaro
Engine: 2.8 v6
Transmission: T-5 5 speed
Axle/Gears: 3.83
I got mine for $1600. 85 rs 2.8 T 5 with a rebuilt engine
it has an iroc hood and a hatch louver that isnt installed yet along with a bunch of free interior parts
it just needs a paint job and some random stock parts replaced
it just needs a paint job and some random stock parts replaced Supreme Member
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Asking Price $800
Paid $795 9/10/1999
He gave me $5 back to get gas
Paid $795 9/10/1999
Car: 89 Firebird
Engine: 2.8L V6
$800, needed a new Throttle position sensor(went thru 3 in a year of having the car), took off cat. converter, needs new fuel tank (previous owners drilled 4 holes into it trying to install an amplifier), and a little body work and paint and that should do... oh i also had a flowmaster muffler put on
So I paid 3900 3 weeks ago for my 88 Firebird with a 2.8. I know I know but hear me out...I have been looking at every 3rd gen around the Columbus area for about 3 months and found nothing but major issues everywhere I turned. I finally decided I was going to buy a 91 TA for 2300 that needed paint and some minor work like interior and moldings. I was just about to call the guy to make the deal when I decided to look at new listings for that day. Thats when I found the car I have now. This car is all original with a laundry list of new to include paint, brakes,battery,alternator,exhaust (still replacing for better sound), tires, rims refinished etc etc etc...still has the original T Top bag. So basically I spent the money up front that I would have spent anyway on resto.
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
My Mom paid $10,000 for my 87 back in 1989. It was her daily driver up until 1998. I got it for my 21st birthday, when she bought a 92 RS... I'm working on getting that car too.
I'm now thinking about putting the 87 back (close) to stock, including a V6
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
i got my 87 sport for 450 bux.. all i need is a timing chain. body isnt in too bad shape. paint job is good cept for 2 bondo's areas. came with a custom stereo with an amplifier and a kicker.aftermarket hood and aftermarket rims. interior is in great shape aside from the discolored carpet. 8ball shifter. and a decent genuine chevy decal on the rear window. picture is in my album if you want to see it. judge for yourself. i think its worth it
Engine: 2.8 MPFI
Transmission: 5-Speed Standard
$1000 for my 87 2.8 % speed camaro. Has t-tops, no a/c, no power windows or locks, no headliner, usual wear and tear on seats. Everything operational. Runs well(except for the fact that its got a fuel problem- 9 MPG). No rust, alright paint job, dings on hood.
Last edited by nezzie09; Jul 8, 2010 at 10:32 PM. Reason: Missed the last sentence.
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I paid $400 for my '89 RS. She wanted $500 for it, but it needed a radiator and new battery (both of which came out of my '84 Z28 parts car.)
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Seriously where is everyone finding all these cheap cars?! Whenever I see a third gen camaro for $500 it either has no engine or trans and an f@$^ed up interior or it has a V6 that needs a tune up and a shot tranny with a messed up inside and outside.
Damn A friend of mine has an 87 Camaro in his backyard that he don't want,he said I can have it,but he don't have the pink slip to the car,some guy down the street gave it to him,only if I can get that slip,I'll take the car.
the guy that gave the car to my friend said,someone else gave it to him. that belongs to an old lady and he couldn't get the pink slip.
damn is there any possible way just to transfer the name to me?
cant I just tell the dmv i found it in the desert field?
I saw an 5 speed 88 firebird for $700 two days ago.. I wanted to jump on it, but I didn't. I've already got a 5 speed v6, and couldn't really come up with a reason to get another one
it's gone as of yesterday
buy the vin #s plates, and a title off a wrecked one from a junkyard, preferrably as close to the one without a title and change everything out.
dunno if it works or not, but its what i always thought i would do if i stole a car, lol. but that was when i was a teenager, haha. not quite a teen anymore.
good luck
Car: 89 rs
Engine: carb'd 350
Transmission: th350
Axle/Gears: 2.73......
i paid 500 dollars, it ran great and had almost no issues on it except for body work.
and after i had her painted
i dont have this one anymore, i decided it was time for a new project.
(note: the new project is not a v6)
kammi10
Nov 9, 2015 08:28 PM
efiguy
Sep 27, 2015 01:30 PM
Chad Speier
Sep 24, 2015 12:32 PM
thejimsterz28
Sep 15, 2015 04:37 PM
Street Lethal
Sep 7, 2015 01:09 PM
