Fuel pressure connection leaking
Old May 24, 2010 | 01:02 PM
generalchase's Avatar
Car: 1991 pontiac firebird
Engine: 1991 3.1l LHO
Transmission: Th700r4
I am having a problem with my Fuel pressure connection leaking on a 1991 3.1l (I call it the schrader valve but I was going by what the service manual calls it). When the fuel pump brings system up to pressure around 46psi the fuel comes out of it in a fairly big stream it doesn't shoot out at pressure just trickles out. If i were to find a cap for it would that stop the leak or do i have to replace the whole valve or does that mean i have to replace the whole fuel rail?
any suggestions would be great thanks
Old May 24, 2010 | 02:14 PM
racethesunlive's Avatar
Car: '92 Camaro
Re: Fuel pressure connection leaking
So the valve is stuck open a bit? If you have one available i'd try attaching a fuel pressure gauge onto the valve and see if that stops it from leaking.
Old May 24, 2010 | 02:38 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
should be able to go to napa and get a replacement for it. not sure if it would be fuel rated. i did that a while back and have not looked back. valve core is what its called. need a special tool to remove it. costs a couple of bux. just take it in to a parts store they should be able to find something for ya.
Old May 24, 2010 | 08:05 PM
got a new fuel pressure connection GM part # 17112759 and repalced the original in about 4 mins.
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
wayshegoes
Aug 17, 2015 12:00 PM
86Base
Aug 13, 2015 05:06 PM
Kaweh
Aug 9, 2015 02:54 PM
