2.8 700R4 shift points
Old Jun 15, 2010 | 10:46 PM
mars061's Avatar
Car: 87 IROCZ Z28
Engine: 3900V6 GT4088 intecooled
Transmission: TH350
Axle/Gears: 3.45 MSF Spool
Where do they shift @ WOT?
My 1-2 is at 6200 - 6300 and my issue is that with the 7730 ECM I just installed to run my 3400 V6, I hit the rev limiter @ 6400 before the 2-3 shift happens...
Do I need to up the rev limit OR is there something wrong with my trans...?
Otherwise driving around on the street, it's mint though ?
Old Jun 16, 2010 | 02:24 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: 2.8 700R4 shift points
could be the tv cable adjustment is off a little. my 730 doesn't have a rev limiter...i've turned it 7k (by the tach...may or may not have been right). well, if it has a limiter, its high! if you can change the limiter on yours, just do that.
Old Jun 16, 2010 | 05:26 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Need to know the year of the car before I can post up... There's 2 different sets of shift points, IIRC, depending on the year, because of changes within the transmission. However, it definitely sounds like either the TV cable has stretched or the valve is stuck or the governor valve is stuck, or you have low oil pressure in the trans.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
