Grand National drivetrain?
Car: 1994 Z28
Engine: 355 LT1
I'm throwing around ideas right now for my next project... I have a 86 camaro that was originally a v6 car, converted it over to a 350 but left stock suspension.
My question is what is necessary to swap in a grand national motor (along with all the accessories and piping?) I'm finding these motors with full harness and computer for a fair price and the 200r4 is a relatively cheap trans to get my hands on. Not concerned with the obvious things like trans mount.
Car: 1992 Z28 Coupe
Engine: LB9
Re: Grand National drivetrain?
I think your best bet would be to compare your specs with the TTA ( Turbo Trans Am ) My dad has a GN and is pouring cash into it. His mechanic has a GN and a TTA. He said that there was an issue with GN heads getting in the way of some things so GM used an alternative head for the TTA. I'm just passing what little I know since nobody has responded. However, could be a good starting point.
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Personally if you're looking for a powerful v6 there are other easier options, like a 3.4 or a 3500. Otherwise I imagine pretty much everything off a donor car.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Which can handle up to 750HP with little mods. After that you want the aftermarket billet block.
Engine: 3.8, 3.4
I'm not talking about power making being easy, retrofitting a 90* v6 into an F-body is every bit a PITA that dropping a v8 in is, in which case imo you might as well drop a v8 in, or go with a 60/6 that will go in a lot easier.
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
dropping a v8 into these cars is a PITA? you just must not know what you are doing....
a motor swap in these cars takes a few hours at a lazy pace if you know what you're doing.
Engine: 3.8, 3.4
You're both missing my point, my point is, if you're only after say, 400 hp, its a lot easier to just put in a 3.4 or fwd 60/6, then going and getting an entirely new drivetrain, and retrofitting it. Now if you're after crazy hp levels, then yes, its probably necessary, but most people don't need or want 750 hp. But think if they want more the 60/6 is worthless.
On Probation
a 3.8 gn/tta will do that with just the boost turned up and minor bolt ons.
its NO easier to swap in a 3.4 or fwd 3.8, then it is to swap in any other common GM based engine, its foolish however to choose that 60* JUNK that GM spit out.
To the OP,its been so long, but i beleive you need to use buick lesabre FWD 3.8 heads for a GN 3.8 swap, research before hand, but its along those lines, i seem to recall there being some sort of strut tower/frame rail clearance issues on the pass side for the turbo mount or something, thats why GM went with the different head.
Check out turbobuick.com and research this ALOT before you procede.
Engine: 3.8, 3.4
A 3.4 is a direct bolt in replacement, so yeah, I would say that's easy. And a 3.4 hybrid could make 400 hp without boost, and boost does wonders, a near stock 3.1 can easily make 400 hp with a turbo, and the FWD engines can at least use the same transmission, so yeah, once again its still easier even with a fwd 60/6.
But once again, it all depends on your power goals, pocketbook, and resources, I'm only trying to make the point, that if you have relatively modest power goals, you shouldn't altogether rule out working with what you have since it IS easier, and cheaper.
On Probation
the heads do not flow enough, lacks cubic inches..etc etc.
and a near stock 3.1 is NOT going to make 400 hp with a turbo, nor would a 3.4, you are talking about MORE then doubling the engines power output, it wont happen... its possible{with ALOT of boost} but, it wont be reliable, and wont be cheap.
THE easiest, and cheapest thing he can do, is to throw away that boat anchor 60* v6 junk, and go to a REAL motor....but if you read his post, you will notice he has no motor, car was originally a v6, then v8 swapped.
Honestly, since its v8 swapped already, id stick with v8, GN swaps arent cheap because there motors hold value.
Refer to my sig, my combo makes awesomepower, gets 24+ mpg hiway, runs 12s on motor,deep 11s on nitrous{would run 10s on slicks EASY}, and its a basic cheap combo to duplicate.
Engine: 3.8, 3.4
Yes, the cam would have to be quite large, but it's doable, and you're wrong about the 3.1, cam, and porting will get it there easier than you might think, just look at project89's car.
On Probation
i only see numbers 130+ rwhp short of your "400 hp is easy" claims...
with enough money, of course its doable, but its also foolish, for the same money, and id bet LESS money and far less effort/labor...you could have more power, better reliability, and far more potential.
My thrown together junk 350 puts down 30 rwhp more, with basically all factory GM parts, still keeping TPI, next month with the larger cam/intake swap i fully expect around 360/375 rwhp on motor.
Car: 1994 Z28
Engine: 355 LT1
I had frame rail problems clearance problems when I dropped a big block into my iroc, we basically notched the rails and enclosed them, long story short it held up fine... but if it requires more clearance then the big block did, I don't think boxing off the frame rail will work.
I guess if I can't find any solid information on this topic I'll just have to figure it out on my own, I'm 20 years old (so I'm not as experienced as some of you) but I have a lot of experience with fabrication and my old man will help out. Worse case scenario the motor goes into something else.
On Probation
heads were used because of clearance issues for A/C, so it might be ok to use GN heads if you dont intend on using AC.
Car: 1994 Z28
Engine: 355 LT1
i did a bit more research, looks like they used mid 80s lesabre heads, and the TTA shortblocks had different pistons to keep CR the same as the gn..
If the only reason they switch heads is to retain AC, I will yank the AC out. I'm not interested in building another V8, I have a pretty fun one already. I am positive I want to give it a go with the little turbo cars.
Car: 87 GTA
Yes, the TTA heads were different than the GN/GNX/Turbo T-type cars. And IIRC, a different turbo was used as well.
I'll keep looking for info on this.
Car: 1994 Z28
Engine: 355 LT1
https://www.thirdgen.org/buick-3.8L-...ne-swap-f-body
What I am getting out of it:
Pull the AC and buy the adapter plate to mate the GN motor to the 700R4. This saves a lot of time and work, retain the stock torque arm and trans mount. Other then that the only real issue seems to be the exhaust because they are claiming the TTA manifolds have been discontinued and the GN manifolds will not work.
Car: check
Engine: check
Transmission: check
I believe that the reason for the different exhaust manifolds is due to the different heads. By keeping the GN heads the GN manifolds will work.
What GM did on the TTA for the torque arm was to mount it to the cross member. There are aftermarket ones that are mounted this way. So using the 200-4R is still possible with that type of set up.
There is a guy on here with a thread that did put a GN engine/trans into a Camaro. Not sure if I could find it.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Car: 1994 Z28
Engine: 355 LT1
all the piping looks like it's going to be a very tight fit... thanks for that link.
Car: 1988 Camaro IROC Z
Engine: Buick 3.8 V6 turbo
Transmission: th400 with TB
Axle/Gears: Mosser 9" 3.50 9.44@146.7
You can go to my web site, I took lots of pics to show how I did my swap.
And dont miss the V8 at all.
www.aaperformance.org
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by zraffz
My question is what is necessary to swap in a grand national motor (along with all the accessories and piping?) I'm finding these motors with full harness and computer for a fair price and the 200r4 is a relatively cheap trans to get my hands on. Not concerned with the obvious things like trans mount....
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
The GN setup is proven to make a ton of power however to up the fun factor i'd copy a Sy/Ty setup.
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
I'm doing that swap right now. Great project to do, different than the usual.
PS, the stock Gn heads clear just fine, as well as the stock exhaust maniofolds. The heads just don't fit with Air Conditioning. I even used a GN downpipe. I just had to modify it a bit at the one end. Nothing an exhaust shop can't do.
Car: 1992 Z28 Coupe
Engine: LB9
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Why I aughta!!Lol, seriously though any 60* with iron heads is junk. The iron heads/induction are pure junk. Newer fwd heads/induction are a different story though. And as far as durability is concerned mine's actually suprised me with what I've been able to do to it so far. Here.
I thought about throwing a syclone motor in mine awhile ago, that would make a fun project. A guy that comes to my shop has an otherwise stock one he's turned up the boost a little on. I was more than impressed with how hard it launched.
Originally Posted by JeffGordon
Auto / Manual Trans?? Sounds like a cool build. Link please! So I wondered my whole life why the GN only came with a automatic. Short answer.... It's quicker and looses less boost. I have read about GN folks swapping in a manual trans. I have heard less than good about the outcome (performance wise). However, for a manual trans freak like me, I wouldn't take it any other way!
http://www.streetfire.net/video/full...d-i_124110.htm
Chevykid810
Sep 28, 2015 12:57 PM
