2.8 radaitor overflow and windsheld washer fluid containers
Old Jun 29, 2010 | 10:33 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
I just bought an 86 camaro with a 2.8 and these containers are gone so im replacing them off my 90 camaro but i cant figure out where they go on so any help?
Old Jun 30, 2010 | 03:36 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 2.8 radaitor overflow and windsheld washer fluid containers
They mount to the front of the wheel wells... Search for a couple of my pics and you'll see where. If not, LMK, and I'll send you to my CarDomain page. They only fit in one way, and the holes will line up when the bottles are lined up. Use either a couple of bolts and nuts or small plastic push pins (used to hold the plastic inner fenders to the sheet metal fenders).
Old Jun 30, 2010 | 03:38 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
FYI, the style and design of the bottles changed around 87-88, so it's very possible the ones you have won't work without modding them
new bottles are cheap, try ebay
Old Jun 30, 2010 | 03:40 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Don't know for sure about the coolant bottle, but I've been running a 91 windshield washer bottle with the washer pump for months now. They should plug right in. The washer pump in the wiper motor (which I would recommend replacing with the one from the other car and rewiring the harness) just pulls the washer fluid through the other pump.
Old Jun 30, 2010 | 03:41 PM
Engine: L31 350
i know where they mount i just dont know what bottle goes where like on which side they go on.
Old Jun 30, 2010 | 03:42 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Washer bottle by the battery, if the battery is on the driver's side... They're shaped to go only on one side .
DIRTY JERZY's Avatar
Car: 89 formula 350 & 2001 ws6 ta
Engine: 350 tpi & ls1
Transmission: 700r4, t56
Axle/Gears: 9 bolt ? & 10 bolt 3:42
washer fluid on the driver side coolant on the other
Old Jun 30, 2010 | 03:43 PM
58mark's Avatar
washer - drivers side
radiator -passenger side
Old Jun 30, 2010 | 03:50 PM
Engine: L31 350
ok thanks guys. the reason couldnt figure it out was that the radiator overflow tube?, was to short to reach the passenger side so someone might of cut it so ill just have to get a new hose. thanks again.
Old Jun 30, 2010 | 11:45 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
The bottles changed, but the shape of the engine bay didn't. Bottles from any '82-'92 should work just fine.
Fireslash
Apr 11, 2016 06:43 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
mfp189
Sep 27, 2015 09:25 AM
