1991 3.1 code 43, lacks power
Old Jul 16, 2010 | 11:36 PM
c3c4vettes's Avatar
just purchased a 91 rs with the 3.1 auto and car lacks power, check engine shows code 43, esc problem, what are the usuall fixes
Old Jul 18, 2010 | 10:09 AM
JuggaloRon's Avatar
Car: 86 camaro berlinetta
Engine: 2.8, soon to be 3.4 w/ turbo plans
Transmission: 700r4(rebuilt in jan. '10
Axle/Gears: stock 3.23 open
Re: 1991 3.1 code 43, lacks power
43 TPS (Throttle position sensor) out of adjustment OR knock sensor signal error OR low voltage at electronic spark timing control.
thats what my book says for a code 43. hope this might help
Old Jul 18, 2010 | 01:30 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Um, code 43 is usually a bad knock sensor, located as a coolant plug down by the starter. It's either that or there is an ECM error.
The guy above is referring to a different code...
jhawkeye
May 25, 2022 06:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
InfinityShade
Aug 22, 2015 08:00 PM
mdtoren
Aug 16, 2015 05:45 PM
