Advance timing
Old Sep 16, 2010 | 12:44 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
Advance timing
I want to advance my timing to get a little bit more performance out of my V6. How far can I go and still have a safe running engine that still gets decent gas mileage?
Old Sep 16, 2010 | 03:17 PM
cj92firebird's Avatar
Car: 92 Pontiac Firebird
Engine: 3.1L FI
Transmission: Borg Warner T5
Axle/Gears: Stock 3.42
Re: Advance timing
I ran mine at 12* BTDC and I had no problems with gas mileage, and it ran great.
Old Sep 16, 2010 | 03:58 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Advance timing
I wouldn't go much more than 18* or you'll have starting problems...
Old Sep 16, 2010 | 09:42 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: Advance timing
What does BTDC stand for? haha
Old Sep 16, 2010 | 10:05 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Advance timing
BTDC = Before top dead center. TDC is 0* timing.
Old Sep 16, 2010 | 10:08 PM
Engine: 3.1L FI
Re: Advance timing
Old Sep 16, 2010 | 11:44 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: Advance timing
Oh thanks haha I know what TDC is but I didn't get it with the B for before haha thanks guys, I'll give 12* a whack next time me and my buddy are in the garage and see how it goes.
What kind of mileage did you get out of yours at 12* Cj92Firebird? I get about 28 pretty consistently with mine on time.
Edit: What kind of a detrimental effect is this going to have on my car? Its got 88K miles on it now, and I want it to last. How do these things stand up to time with the timing advanced? I drive this car everyday and have for the past two years now. I don't want to hurt my baby!
Old Sep 17, 2010 | 12:30 PM
Engine: 3.1L FI
Re: Advance timing
Well, I never really had a benchmark for my car. When I got the car it had a blown motor in it, so the motor I got for it, I did a few things to that reduced my gas mileage and increased performance. But with my 12* and my mods I still got about 24 MPG on the highway.
I put 2,400 miles on my motor with the timing advanced before I blew a lifter (which had nothing to do with the timing), never had any abnormal effects with starting or anything. It ran like a scalded *** ape.
Old Sep 17, 2010 | 03:07 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: Advance timing
well maybe ill start with something conservative like 8 or 10 and go from there
Old Sep 17, 2010 | 03:14 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Re: Advance timing
Isnt 10* BTDC standard?
Old Sep 17, 2010 | 03:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: Advance timing
Killert's right, 10 degrees advanced is stock spec (engine won't run at 0 degrees, and I certainly wouldn't retard it down to 8 degrees or less).
Overadvanced timing can cause detonation- so check your spark plugs; if they start looking strange (or damaged!) then you went too far. If you flip thru a Haynes manual they'll have spark plug pictures; I believe a few are listed for detonation. And of course if the detonation was severe enough you could destroy a piston...
I played with my timing a lonnnng time ago, I tried 12 and 14 degrees advanced; didn't notice any difference, so I went back to the stock 10 degrees.
Let us know what you find out!
Old Sep 18, 2010 | 11:37 AM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: Advance timing
So if 10* BTDC is standard, then are you guys talking about advancing another 12 degrees or just 2 more degrees past TDC? What point are you using as your zero? Is 10* really 10* or are we just calling the 10* zero and then going from there?
Old Sep 18, 2010 | 03:03 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Advance timing
We're calling 0* of advance (TDC) zero...
Old Sep 18, 2010 | 06:26 PM
Engine: 3.1L FI
Re: Advance timing
The stock timing setting is 10* BTDC. I'm talking just advancing it 2*s to 12* BTDC. I've heard of people running 14* with no problems, and they said they could tell a difference on the butt dyno without much effects to gas mileage and such.
Old Sep 27, 2010 | 05:17 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: Advance timing
does anybody know if we need to disconect any of the dizzy wires before timing the car ? my haynes is a bit shady, i have a 2 wire and a 3 wire connector.
Old Sep 27, 2010 | 02:17 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Advance timing
There will be a single wire connector coming out of the wiring harness by the blower motor for the HVAC that needs to be disconnected before the timing can be set. Nothing is disconnected at the distributor.
Old Sep 28, 2010 | 12:59 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: Advance timing
Maverick's right about the wire location. The wire isn't anywhere near the distributor. When engine is off, disconnect it. Then start engine; it'll stumble but run; then you set your base timing. When you're done, shut the engine off, turn the key off all the way, then plug the connector back together. Be careful b/c it might be brittle and the safety-clip-tab might snap off (guess how I know!!).
Although I helped with an engine swap once (2.8 to 2.8) in an 88 Camaro- when we went to set timing, we couldn't find the connector anywhere! We must've compared his car with my Firebird for hours. For some reason it was gone. The previous owner had messed with the wire harness (there was some strange kill switch rigged up) so I think he either cut the wire out or rerouted it somehow. I wound up timing it by ear
Amillionoh7
May 24, 2020 08:01 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
