60 Degree 3.1 MFI OHV V6 Stardard 91 Firebird/Camaro Starndard Bore and Spacings
Old Oct 15, 2010 | 09:34 PM
FireChicken!!'s Avatar
Car: 1991 Pontiac Firebird
Engine: 383 Stroker, 510 BHP Arnd 450 to Wh
Transmission: TH 350, 3000 Stall. built by ACT PC
Axle/Gears: ford 9" Posi, 3.56?
Can any one tell me all or a majority of to Bore's and spacings for a 3.1 V6
I just recently Switched to a 383 Stroker
and I'm rebuilding the original 91 Firebird 3.1 V6 for another firebird
I mainly need to know the
Cylinder heads ports(valves and intake/Exhaust)
Valve Specs(Including Springs, standard length, lift?)
Cylinder Bore
is there any shaved pistons available
piston Ring Size
Cam Specs(Bearings, Height, size)
Push rods length
Lifters
Crank Shaft
Mainly need the Cylinder, Pistons and rotary Assembly Specifications
You help will be greatly appreciated!!!
vortech305
Oct 1, 2007 11:52 AM
zerogsx
Apr 1, 2002 06:44 PM
vortech305
Jun 3, 2001 11:24 AM
Jester
May 8, 2001 12:25 AM
