Any hybrid 3.4/3400's?
Old Oct 23, 2010 | 01:24 AM
crazyman's Avatar
I've always wanted to build an RWD 3.4 block with the flat top pistons, use the FWD aluminum heads for airflow and 13:1 compression or so, cam it, and build a custom six one barrel carb intake with chrome velocity stacks through the hood, and run it on E85 to quell the compression.
Has anyone seen anything like this?
Old Oct 23, 2010 | 08:40 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Any hybrid 3.4/3400's?
I haven't seen that exact combo, but sounds interesting.
I would opt for EFI over carb though.
Old Oct 23, 2010 | 11:15 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
It can run better with efi. Purple82ta has individual throttle bodies on his 3500 and it looks pretty killer.
Old Oct 24, 2010 | 02:23 AM
crazyman's Avatar
Velocity stacks sticking thourgh the hood with individual carbs would be a show stopper and sound great, though.
Mixing and matching said parts would create a thirsty, great looking, fast, high CR motor...
Old Oct 24, 2010 | 10:28 AM
Oh ****, another one of these threads.
Old Oct 24, 2010 | 09:28 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
If this keeps up, you're gonna have a aneurysm, huh?
Old Oct 24, 2010 | 09:32 PM
Yeah pretty much. lulz.
Old Oct 24, 2010 | 09:34 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
im gonna just start copying and pasting the write up 3rdgenrs did
Old Oct 24, 2010 | 09:42 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Mixing and matching said parts would create a thirsty, great looking, fast, high KR motor...
Fixed
While i understand the need for an engine to "look cool" that certainly doesn't dictate how it will perform. You need to spend some time researching things before throwing a bunch of crap at the wall to see what sticks. tuning 6 small carbs will be a nightmare. If one float sticks you're screwed.
Use 3.4 DOHC pistons and 3500 heads, keep it fuel injected. With the right cam you should make some decent power. Just be sure to use a good timing chain and check your piston to valve clearances. Too much exhaust duration and you'll have a paperweight.
RaverRacerX
Mar 17, 2026 01:49 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
merlot-fro
Apr 11, 2015 10:28 AM
91greenbird
Feb 3, 2006 07:31 AM
Gumby
Oct 6, 2005 01:05 PM
