cold start problem
Old Nov 20, 2010 | 11:02 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
cold start problem
When its cold outside my car idles really low and every once in awhile she will die because of the low idle, like today, i went out to start her so i could move her really quick and when she first started she ran for a few seconds then died, after i restarted her and kept my foot on the gas for a few seconds she idled fine till i got out to the end of my driveway she died again. is this normal on thirdgens? should i just give my engine more time to warm up before i put it in gear? anything i can do to get rid of this problem?
Old Nov 21, 2010 | 02:51 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: cold start problem
Could be a couple of things, my first guess is that your CSI is either bad or not hooked up, it could also be that your idle speed is set too low, disconnect the battery for like 5 minutes, hook it back up, and see if it still stalls on you. Do you have any problems when its warm out, or any ecm codes?
Old Nov 21, 2010 | 07:39 AM
Engine: L31 350
CSI should be working, it was working when pulled out of the 3.1 car, im running 3.1 injectors and also she will fire right up on any day that its freezing out its just after i put her in gear right after i start her up, also im getting no codes and she runs fine after shes idled a couple minutes and runs beautifully when shes warm, like i said its only after i jump in, start it, and throw it in gear.
Old Nov 21, 2010 | 12:38 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
That CSI and fuel injectors worked fine on my engine...
My guess is the MAF, especially since it's fine when warm. Keep in mind that a bad MAF won't always throw a code (and if it does, it may not throw a MAF code). Did you replace it when you finished things up and got the engine running, or is it the same one that came with the car? Also check the CTS resistance.
Old Nov 21, 2010 | 12:43 PM
Engine: 3.8, 3.4
Try cleaning the throttle body around the blade, and the IAC, and check if any vacuum lines are, chances are its an issue thats always present, but just made worse by the cold, but I think its the CSI, you said you swapped to the 3.1 injectors, did you use a 3.1 fuel injector rail? there is a 7th injector at the back base of the lower intake manifold, that is the CSI(cold start injector) if its not hooked up or working it could quite likely cause the exact issues you are having.
Old Nov 21, 2010 | 12:47 PM
Engine: 2.7L V6
Axle/Gears: 4.41
He has the 2.8 fuel rail and CSI with 3.1 injectors I traded for a rad fan and upper mount a couple months ago...
I agree with the vacuum lines check...
Old Nov 21, 2010 | 06:42 PM
Engine: L31 350
dan, the MAF is new, i replaced it right before the car went down due to timing, also i know i have atleast one vacum hose leaking and i have one missing but i could never figure out where the line was suppost to go, but when i go friday to the junkyard im going to look to see where it goes, the line thats leaking is the top line off of the charcoal canister, the missing line is under the TB, it connects to a three way connector, the charcoal canister lines also run to it( if anyone here could look and tell me it would help alot), dan whats the CTS? and how do i do a vacum test?
Old Nov 21, 2010 | 09:28 PM
Engine: 2.7L V6
Axle/Gears: 4.41
http://s988.photobucket.com/albums/a...onssticker.jpg
Check this first and get those lines hooked up... If the engine does the same thing after you get the vacuum leak taken care of, we'll look elsewhere.
:edit: The canister connections are the same but on the other side of the car, obviously...
Old Nov 22, 2010 | 08:15 PM
Engine: L31 350
funny thing is, the car started fine today, no problems, it must just e when its cold OUTSIDE surrounding my car, idk i might try to start it when its 40 something out and see if i have problems. the car ran great and started great until i started lossing fuel but thats another thread.
Old Nov 22, 2010 | 08:57 PM
Engine: 2.7L V6
Axle/Gears: 4.41
When it's cold outside, the engine sucks more air into that wide open hole in the vacuum line... I have to get at my gas tank in the garage tomorrow to tell you what's what there for sure.
Old Nov 22, 2010 | 09:10 PM
Engine: L31 350
ok thank you dan
Old Nov 22, 2010 | 09:43 PM
Engine: 2.7L V6
Axle/Gears: 4.41
As for the PM you sent, you can get the MAF clamp at a parts store. I believe it's a 55-68mm clamp, but I need to look at the ones I have in the garage to make sure. As for the rubber ring that goes on the end of the air box to seal to the MAF, if you don't have it, you're SOL.
I know that the fuel line towards the front is the pressure line (the biggest one) and the one at the back is the vent valve line. I think that the other 2 cross between the sending unit and the body lines, but I'm not 100% on that, which is why I need to look at mine. As for why the fuel is coming out in such large quantities from the vent valve, that's anyone's guess.
Old Nov 23, 2010 | 03:21 PM
Engine: L31 350
the guy i talked too at autozone said he couldnt get one, he needs one for his 86 iroc, also what rubber seal?
Old Nov 23, 2010 | 03:23 PM
Engine: 3.8, 3.4
its a big fat O-ring, depending on your intake setup you might not have it though, on my car I have dual tpi snorkel intake, and the MAF has a plastic ring on the end that has an o-ring on it to seal it to the air filter box.
Old Nov 23, 2010 | 03:54 PM
Engine: L31 350
i dont remember ever seeing a rubber ring, only that metal ring
Old Nov 23, 2010 | 05:13 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Having just gone through the same problem I'd have to say it's probably the MAF I replaced it and problem gone.
Old Nov 23, 2010 | 05:37 PM
Engine: 2.7L V6
Axle/Gears: 4.41
It's either that (always wondered what that groove was for in that end of the MAF), or there's a rubber ring, similar as is used to seal plumbing, that sits on the end of the air box with one side of the ring on the outside and the other on the inside where the MAF is, and the clamp goes on top.
If you can't find a clamp at a hardware store, let me know. I have about six of them (stainless besides!) in the garage because I can't use them with the new intake.
Old Nov 23, 2010 | 07:09 PM
Engine: L31 350
so can i get it at lowes? like i said i called zone and they said it was a no go., i cant look at the seal till tomorrow maybe, the cars at the exhaust shop (:
Old Nov 23, 2010 | 08:54 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Me thinks they're BSing you... I'm sure they have plenty of 2.5" hose/air intake clamps (commonly used on those aftermarket air intake things, which is where most of mine have come from). If not, then Lowes will have it.
Oh, and you really need to check that MAF sealing deal... If you run too long without it sealed, you'll need a new MAF.
Old Nov 23, 2010 | 09:09 PM
Engine: L31 350
ok ill stop in tomorrow when i get the car, do you have a picture of the rubber seal? i honestly dont think i have it, when i put the MAF in its just like sliding it into plastic, no resistance
Old Nov 24, 2010 | 08:45 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I can say my 86 always liked to warm up a bit, not that I couldn't just take off [easier with a stick, I can play with gas n clutch to make it go] but it was better if I could to let the O2 get hot and work first. And until then the idle was funky, all over the range.
That why newer cars have 3 and 4 wire O2 sensors, it pre heats it, so it works quicker.
Old Nov 24, 2010 | 04:17 PM
Engine: 3.8, 3.4
Surprisingly I have had no drama yet with cold starts, despite not having the CSI hooked up, I have noticed my engine idles high when first started, or when pulling to a stop its initially high, but then drops a good bit and levels off, curious, is that normal?
Old Nov 24, 2010 | 05:27 PM
Engine: L31 350
problems gone away since iv swapped those gas lines around (:
Old Nov 24, 2010 | 08:10 PM
Engine: 2.7L V6
Axle/Gears: 4.41
It's quite normal... If you've ever noticed, any fuel injected car, no matter the manufacturer, will run about 12-1300 RPM until the coolant temp reaches a certain point, and then the idle speed will drop to around 800 RPM or thereabouts. GM's tend to run about 1200 until warm and then drop to about 800 when not in gear or about 700 for a manual (or they will drop steadily on a newer engine). I guess it helps prevent the engine from stalling when cold or something and helps the engine warm up faster to knock the emissions down.
Old Nov 24, 2010 | 08:16 PM
Engine: L31 350
my cars idleing about that now, i have no problem starting the car at all, its 28 here and she fired right up without any problems and she has alot of power since i have that exhaust done!!, dan can you get me a picture of that rubber seal for the maf please?
Old Nov 24, 2010 | 08:18 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I'll have it tomorrow... I've been busy with my rearend most of the afternoon and there is no power to see in the garage at the moment.
Old Nov 24, 2010 | 09:03 PM
Engine: L31 350
wait no!! tomorrows turky day, be with your family dan, if you can get the pic friday, i wont be on from friday till next tuesday, ill be at my dads till sunday, mondays my 16th birthday, and tuesday im getting my permit so i can drive this beastly v6 lol.
Old Nov 24, 2010 | 09:55 PM
Engine: 2.7L V6
Axle/Gears: 4.41
We already had turkey day (5 hours ago)... And I won't have anything to do after work tomorrow, so... Might as well.
Still, if I do have a spare MAF seal, I'll let you know. If you need a clamp, let me know, as I have about six extras (2.75 inch max clamps don't work on 3" PVC pipe).
Old Nov 25, 2010 | 08:04 AM
Engine: L31 350
im going to the junkyard tomorrow to see if i cant salvage one of those rings, a seal, some vac lines, a washer pump and bottle, and water fluid lines. so ill report back soon with my findings if i cant get one of the ring without breaking it like i did my old one or a seal.
92camaroJoe
Jul 29, 2023 07:57 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
