Ram AIR Questions
Car: Camaro
Engine: 2.8 tune port
Ram AIR Questions
So i constructed my ram air on my 2.8 stock v type intake ,
my question is can to much air harm you ?
and my temputure gauge bounces around like crazy does any one els do that to ?
can my ecu handle that much air ?
should i buy a superchip ?
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: Ram AIR Questions
Your engine will never have more air than it can handle, unless you add a turbo. Don't worry about getting a chip, they don't do much.
Your temperature gauge problem seems to be a bad sensor or wiring. I would make sure the wires aren't damaged and replace the coolant temp sensor.
kyle5647
Aug 15, 2015 11:56 PM
