I hear a high frequent noise
Old Sep 11, 2000 | 04:03 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
I hear a high frequent noise under my hood,don't know where it comes from, tried to find out with a screwdriver- negativ.
anybody has an idea?
Horst
[This message has been edited by Horst (edited September 26, 2001).]
Old Sep 11, 2000 | 04:26 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
What exactly does the noise sound like is it a squeal like a loose belt or more like a whine?
"In Racing You Have A SPLIT SECOND To Do It And Six Days To Talk About It!"
http://home.earthlink.net/~singleton052095
Old Sep 11, 2000 | 04:32 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
it' a high whistle
Old Sep 11, 2000 | 05:30 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
sounds like a vaccum leak.. try to find the general area it is coming from by either getting a automotive stethoscope or use a peice of old heater hose about 2 feet in length, put one end up to your ear and move the other end around trying to find it.. there are other ways to find, but ill explain later, since were not even 100% sure thats the problem...
do you have a home made k&n air filter setup? when do you hear this noise? at idle, while driving, at high rpms, etc..
Old Sep 11, 2000 | 05:38 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
the noise is always there, when the engine runs, and the filter is orig. GM
thanks so far to you guys and great to be back to thirdgen.
Old Sep 11, 2000 | 06:27 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
you can also take wrench extensions combine them put to all the accesories and it works the same as a stethoscope but u already have the parts
K&N,MSD Gm Coil,TB Bypass, Flowmasters with Hand Made Tips, Msd Heli-Core Wires, Cold Air Intake, Dynomax High-flow cat,Rapidfires, AND IN ONE MONTH VORTECH BLOWN CUSTOM INSTALL W/ A COMPUCAM! I feel the need to race after that...ill let you guys know after its done, and ill be sure to dyno!
Next:
Cam, Rockers, Pulleys, Msd 6a...maybe a 3.4 crank too..boost torque a bit...
Old Sep 12, 2000 | 04:27 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
New facts,
when the coolant becomes hot, the noise is louder, short before the thermostat opens, sounds like over pressure. Couldn't locate yet where it comes from.
any new ideas?
Old Sep 12, 2000 | 04:42 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
New facts,
any new ideas?
www.marion-becker-nidda.de
Old Sep 12, 2000 | 05:41 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
check your water pump.. does the car over heat at all? any coolant leakage? hopefully you got an electric fan so this is easier, if so, take the belt off the pump, and firmly grasp the water pump pulley, try to wiggle it around and pull it in and out.. there should be no play...
Old Sep 20, 2000 | 04:35 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
it's a coolantleakage, I guess headgasket.
oil looks like chocolatemilk.
sahlomonic
Sep 20, 2015 07:15 PM
amcnellis
Sep 16, 2015 04:16 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Randomtask2
Sep 7, 2015 05:06 PM
