3.4?
Old Oct 11, 2000 | 02:08 PM
astro-creep's Avatar
3.4?
I am rebuiling a 3.4 for my bird. Does anyone know if you can put a 3.8 crankshaft in a 3.4?
Old Oct 11, 2000 | 02:13 PM
Dan84SC's Avatar
Uh, no. Not even close... The 3.8L is a 90-degree V6, and the 3.4L is a 60-degree V6. Even if you could get it in the engine, none of the connecting rods would bolt on because of how the cranks are so different.
They don't even look close to being the same.
Old Oct 20, 2000 | 01:06 PM
94Camaro's Avatar
Car: 1994 Chevy Camaro
Engine: "3400" 207ci V6
Transmission: Tremec 5 Speed (T5)
the connecting rods would bolt up fine, but they would be at the wrong angle, and the cylinders probably wouldn't work because of the pressure being put at the wrong point...
plus... the 3.8L has a different firing style than the 3.4/3.1/2.8. all of the 60* motors i just listed fire 1-2-3-4-5-6 and the 3.8 is like 2-4-3-1-5-6 or something wierd like a v8. its not sequential like the 60* so even if you could get the crank to work, the engine wouldnt fire right...
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
92projectcamaro
Sep 29, 2015 07:07 PM
92projectcamaro
Aug 6, 2015 01:20 PM
87CamaroLT
Apr 23, 2001 09:32 PM
