Carbed V6
Old Oct 16, 2000 | 09:26 PM
Monkie's Avatar
Carbed V6
If I changed my 3.1L into a carbed engine how much HP could I get out??? thanks!
Old Oct 16, 2000 | 09:30 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
well...put it this way. The carbed 2.8 had WAY less hp then the mpfi..same for u
88 Firebird 2.8
MODS (either coming or on):
Flowmaster Cat Back, Random Technologies Cat, 3" intermediate pipe, 10.4 Taylor Race Wires, MSD Coil, MSD Ignition Module, B&M Shifter, Transgo Shift Kit, Cold Air Induction..Then peeling and cracking paint..
2"cowl hood
3.4 engine -new-
s/c'r then im done, maybe some no2...
Old Oct 16, 2000 | 09:38 PM
Monkie's Avatar
Ok then, maybe Ill keep my fuel injector lol. Thanks
Old Oct 16, 2000 | 09:43 PM
88 Firebird 2.8
2"cowl hood
3.4 engine -new-
Old Oct 16, 2000 | 10:01 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
I second Graeme
Old Oct 17, 2000 | 12:48 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I like carbed engines more you can fine tune them to your likeings and you can put in spacers to add More HP and i just see them being funner to fiddle with my moms 403 was carbed and that T/A screamed
Old Oct 17, 2000 | 01:07 AM
Kevin S's Avatar
You can also get a 4bb intake from Edlebrock.
.........Or 2bb,what ever floats your boat
http://www.camaroforum.com/
http://v6fbody.com/
http://nethirdgen.org/
http://clubs.yahoo.com/clubs/tristatecamaro
[This message has been edited by Kevin S (edited October 16, 2000).]
Old Oct 18, 2000 | 06:07 PM
84bird's Avatar
The question should be cosidered is there potential benefit to going with a carb?
1) How many cfm does your current intake flow ?
2) If it is less than 390 cfm and I'm pretty sure it is you could gain hp and extend your potential for rpm's using the holley 390 square bore with vacume secondary's . Additionally , because of the moderated air flow of the carb. you should notice a fatter and flater torq line.
3) Wet plate nos for square bore carb set-ups are between 400 and 500 bucks and are a pretty straight forward to set up.
What ever you deside to do let us know how it goes.
Old Oct 20, 2000 | 06:10 PM
84bird's Avatar
come on some one out there must know how much a injetion setup flows u can gain from a carb.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
