f/p slot in fuse box empty cant relieve pressure in lines
Old Jan 30, 2011 | 05:30 PM
firestein's Avatar
Car: 89 T/A
Engine: 5.7
I have an 85 2.8 firebird, and went to go change my fuel filter and for some reason there is no fuse in the slot labelled for the fuel pump, any ideas on what I can do a buddy of mine can wire it back in but I need to change my filter and i dont want to have fuel spraying all over the place
Old Jan 30, 2011 | 05:54 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: f/p slot in fuse box empty cant relieve pressure in lines
no need to pull the fuse, and it on the pass side fender in the front in a weather pack, 2-3 of them up there, 1 is FP.
Pressure is only held after the regulator, soon as the pump stops, the line bleeds back any pressure though it.
Though its still gonna leak like a sive, be ready to do it fast and have fresh air.
The gas with self siphone out of the tank till empty at a nice steady fast pace.
If you twist a line off cause the nuts are froze, again be ready for it.
Old Jan 30, 2011 | 06:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
does a 85 2.8 have an intank electric pump or a mechanical pump?
Old Jan 30, 2011 | 06:09 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Oh yea, could be, I only know the fuse is up front for FI as I kept blowing it.
Old Jan 30, 2011 | 07:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i would imagine, if the OP's car ran previously, without a fuel pump fuse, chances are there is no intank pump at all...
Old Jan 30, 2011 | 07:25 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
If it's fuel injected it has an intank pump.
A lot of times the fuse boxes will get carried over to the next MY, with changes to the electrical system, but no change to the fuse box labeling.
Old Jan 30, 2011 | 10:01 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i don't know if you have an intank pump or not . BUT , have you thought about just thought about dis-connecting the battery ? always a good idea for any maint. . safety is often not thought of untill "YOU" get hurt . good luck .
Old Feb 1, 2011 | 06:00 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
open the gas cap too. that helps a lot.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
backtothe80s
Sep 5, 2015 12:39 AM
TheExaminer
Aug 26, 2015 04:59 PM
Kaweh
Aug 9, 2015 02:54 PM
