3.1 to 4.3
Old Nov 5, 2000 | 07:38 PM
steven's Avatar
3.1 to 4.3
how much of a difference is there between the two V6's, i was thinking of changing my 3.1 out for a 4.3 V6, can i do this?thanks
191(3.1)V6 1992 Pontiac Firebird,K&N drop in filter, bosch patinum spark plugs, Sony 6x9 xplods, 2" tweeters, a 12" optimus, 8" bass tube powered my a 300 watt jenson amp, check it out at www.geocities.com/my_92firebird
Old Nov 5, 2000 | 08:42 PM
Kevin S's Avatar
To switch in a 4.3 you will need the trans for the 4.3, the wiring harness and ECU.More or less it is equal to dropping in a v8.
http://www.camaroforum.com/
http://v6fbody.com/
http://nethirdgen.org/
http://clubs.yahoo.com/clubs/tristatecamaro
[This message has been edited by Kevin S (edited November 05, 2000).]
Old Nov 5, 2000 | 11:42 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
And also it wont fit the heads r too big ive herd
Old Nov 6, 2000 | 07:56 AM
Brian K's Avatar
As with any engine swap you have to be willing to spend lots of time and be patient as it gets working correctly. If your looking for raw power the V8 is the way to go now if your looking ot be different like msot of us the 3.8 and 4.3 would rock. Personaly I would try and find a 3.8 turbo or build that 4.3 and super charge it... Have fun
-KMAK
Old Nov 6, 2000 | 01:37 PM
Mike Harvey's Avatar
I also wanted to do this but found out from the smog technician that it won't pass smog laws but it would pass smog though. The reason why it would be an illegal smog issue is b/c that engine is not in the same classification as a passenger car b/c it was never offerred for a GM passenger car, only the trucks. I don't know how different Texas is compared to CA when it comes to smog laws. I was also told that the engine would just not clear the strut towers as well
- Mike Harvey -
Old Nov 6, 2000 | 04:19 PM
I EAT T/A's Avatar
Car: '87 Camaro
Axle/Gears: 10 bolt, 3.23 posi.
That sounds like a cool idea, but very time consuming aslo. Have fun.
Elephantismo
Feb 13, 2019 12:51 AM
cking99
Sep 22, 2015 11:33 AM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
