where does this go?
Old Feb 11, 2011 | 02:50 PM
88rsbenjy's Avatar
Car: 88 camaro rs
Engine: stock 2.8L V6
Transmission: stock
Axle/Gears: stock
where does this go?
i found this just sitting on top secured by nothing
Attached Thumbnails where does this go?-dscn0352.jpg   where does this go?-dscn0353.jpg
Old Feb 11, 2011 | 03:03 PM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
Re: where does this go?
that would be the coil....it bolt on the side of the motor...probably the exhaust manifold.
Old Feb 11, 2011 | 03:20 PM
88rsbenjy's Avatar
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
ok thanks man, just 2 bolts right?
Old Feb 11, 2011 | 03:29 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Intake manifold I think, not exhaust manifold - ex man heat wouldn't be good for it.
Old Feb 11, 2011 | 04:03 PM
ymenic's Avatar
Engine: 307
Axle/Gears: stock
Yep the 2 bolts on top of the exhaust manifold.
Old Feb 11, 2011 | 05:08 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
It has 4 bolts and 2 brackets on a larger bracket holding the EGR valve and parts that yes, is bolted to the exhaust manifold. Not good for it, but I guess there wasn't anywhere else...
Old Feb 11, 2011 | 05:15 PM
Blue1990camaro's Avatar
i told u what that was ealier ben =) its ur ignition coil, bolts to the side of the engine, if i remem corectly on my 90 RS it used a exhaust manifold bolt
by the way its me Tyler bud
Old Feb 12, 2011 | 10:23 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
They easily could have put it on the firewall or one of the VCs imo. But I think I recall that someone relocated one and it didn't make a difference in how hot it got, so idk.
