Monkie
Old Nov 14, 2000 | 09:07 PM
mhugo's Avatar
Monkie
How the heck do i unbolt the sensor from the housing. It wont come off for anything. Would it be easier to buy a new one?
1992 RS 3.1L
Mods:
K&N Drop-in filter
Mods to come:
New Plugs and wires(need advice on types)
Dynomax Cat Back
MSD GM Blaster Coil
Cold air intake
NEED OTHERS HELP ME!!!!
Old Nov 14, 2000 | 09:46 PM
Monkie's Avatar
You're talking about the open air intake I was helpin you on? The sensor that goes into the box right? If so you dont unbolt it. I thought you did that too but you dont (Well I didnt). This is how it works... That bolt you are trying to take off is the place where the sensor clips into. So all you are doing is unclipping it. Its very simple to do, I cant really explain how you unclip it but if you just look at it up close I think you will figure it out. Look at it tomorrow when you get a chance and tell me if you see how its clipped on. Later man!
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
8.5mm MSD Ignition wires
TB Coolant bypass
Old Nov 15, 2000 | 01:28 PM
mhugo's Avatar
Okay I got the air box out to do which I had to unclip something from it. Now whenever the engine runs for a few minutes I get the SES light on. I think mayb its because I have to take something off of the airbox and clip it back into that clip. Am I right?
1992 RS 3.1L
Mods:
K&N Drop-in filter
MSD GM Blaster Coil
Mods to come:
Dynomax Cat Back
Cold air intake
Old Nov 15, 2000 | 03:02 PM
94Camaro's Avatar
Car: 1994 Chevy Camaro
Engine: "3400" 207ci V6
Transmission: Tremec 5 Speed (T5)
hey - you guys are talkign about a large bolt-like object in the Air elbow or air box..im assuming you are speaking of the Inlet Air Temperature (IAT) Sensor.
if so, thats the reason your SES light comes on. the engine NEEDS your IAT sensor (fuel injection here) to sense the coldness/warmness of air and to allow a certain amount of fuel to come into the engine. yes you can take them off, but you need to get a resistor or something to plug into the sensor wiring to trick the computer at the very least, or your mods will go to **** cause the computer will go into "limp-home" mode when it sees there is no IAT!
at least figure out a way to trick the computer into thinking there is something there...
-R
Old Nov 15, 2000 | 05:58 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
unscrew (7/8ths hex head if i remember right) the IAT from the airbox and plug the sucker back in, move it so its near a source of cool air.. itll be fine.. mines been hanging in front of the rad for over a year now, no problems..
[This message has been edited by scoob8000 (edited November 15, 2000).]
Old Nov 15, 2000 | 06:08 PM
Monkie's Avatar
Wow, I just learned something new. oops
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
TB Coolant bypass
Old Nov 15, 2000 | 08:20 PM
Monkie's Avatar
Ok, just hooked the sensor housing thing back on and I could tell a difference right away! By far the best mod I have done yet lol!
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
TB Coolant bypass
Old Nov 15, 2000 | 08:53 PM
mhugo's Avatar
That d*mn hex wont come undone. Ive had like 5 people try. Is it possible just to buy another one?
1992 RS 3.1L
Mods:
K&N Drop-in filter
MSD GM Blaster Coil
Mods to come:
Dynomax Cat Back
Cold air intake
Old Nov 15, 2000 | 09:40 PM
Monkie's Avatar
You can but its really not worth it. The only reason is if you rounded the thing so bad to where you couldnt get a grip on it. Here is how to get the sensor housing off. Take the air box OFF to where you are holding it. The sensor housing will still be bolted in. Put the box on the ground (carpet is best) face down (open end down). Get an adjustable wrench. Get the wrench on it to where it has a GOOD *** GRIP on the bolt. Get someone to hold the box down while you pull/push it towards you. With some good man power it will come loose. But it is not easy at all. But, come on Im 16 and I got it off! Good luck man! Let me know how it turns out! Later!
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
TB Coolant bypass
Old Nov 15, 2000 | 09:41 PM
Monkie's Avatar
Oh and about the plugs and wires... Im getting MSD. I feel they are the best.
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
TB Coolant bypass
Old Nov 15, 2000 | 10:35 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Take some WE40 or liquid wrenc and spray it on it let it sok for 10 mins then give it a shot
Old Nov 16, 2000 | 10:51 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I know I'm annoying but- 85-92 = MAT. 93-up = IAT.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 16, 2000 | 04:40 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
tom, huh?
anyway, i dont know if they put some sorta thread sealer on that damn thing or what but mine was a total mother to get out too, thought i was gonna crack the airbox.. but yeah its a under 10$ part from autozone.. just ask for a replacement IAT (incoming air temp sensor) for your car..
Old Nov 16, 2000 | 08:37 PM
Monkie's Avatar
$13 I think from Next Gen. Yep it is hard to get off. But it is possible. scoob8000 did you get it off by what I said? Or did you take your own route or have it already off?
Oh and did Gramer ever get this done? HEY GRAMER YOU OUT THERE!?
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
TB Coolant bypass
Old Nov 17, 2000 | 01:13 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
There's no such thing as an IAT on our car.
That's 93-up terminology.
Our 3rd gens call it a MAT- Manifold Air Temp.
Old Nov 17, 2000 | 07:30 PM
Monkie's Avatar
Everyone knows what he is talking about
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
TB Coolant bypass
Old Nov 17, 2000 | 08:05 PM
Garmer's Avatar
Monkie, first off, it is Garmer! NO I havnet done it yet, hopefully this weekend, but I am also going to put my other tires on!
91 RS Camaro
3.1L
Cat Back System, K&N filter,modified air box, Fastchip Stage 2, 160 thermo, Rapidfires and Bosch Wires, soon to come: Homemade Ram Air,and maybe power pulleys, 5 Air Horns
Old Nov 17, 2000 | 08:28 PM
Monkie's Avatar
Oh, oops my bad!
EDGE
Jul 13, 2015 09:32 AM
space_monki
Members Camaros
Apr 27, 2009 03:45 PM
5.0mustang
Theoretical and Street Racing
67
Oct 1, 2002 12:35 AM
IROCME
Apr 27, 2002 02:16 PM
Violate 3.8
16
Nov 15, 2001 02:59 PM
