Dummy Lights
Old Nov 17, 2000 | 02:42 PM
knighthelm's Avatar
Dummy Lights
I have a quick question
How hard is it to change from the dummy lights of the oil temp and volt. to working gauges?
Old Nov 17, 2000 | 02:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Not hard... for the oil gauge, you remove the dummy light "pressure switch" from the motor, and replace it with either the tubing for a mechanical gauge, or the "pressure sender" for an electrical gauge.
For a voltmeter, you just hook it up to the car so it gets voltage only when the car's on.
There's a ton of gauges in Summit Racing's catalog, or you can also search the internet for some of the gauge maker webpages, like AutoMeter/AutoGage, SunPro, VDO, Intellitronix, etc..
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 17, 2000 | 08:23 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
If you have a Camaro it is a simple swap to change a dummy light cluster to a gauge cluster.
Here is a tech article on the swap: https://www.thirdgen.org/newdesign/tech/gauges.shtml
"5 out of 4 people have a problem with fractions"
My Camaro: http://home.earthlink.net/~singleton052095
[This message has been edited by CC_HotRod (edited November 17, 2000).]
Old Nov 20, 2000 | 12:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oops, I mis-read, didn't know he wanted the whole cluster
Old Nov 23, 2000 | 12:09 PM
knighthelm's Avatar
so the cluster of an Iroc will fit in the V6?
All the wiring is there?
All I have to do is change the senders and make sure the wires are connected?
Old Nov 23, 2000 | 02:35 PM
pods8's Avatar
If you are happy with your speedometer and tach(if you have one) and all you want is the oil and volt gauges I have some off an old cluster.
-pods
88' Sport Coupe W/ T's
2.8->3.4 5-speed, accel coil-8.8 wires w/ bosch platinums
black and silver, grey interior, w/ 95' cloth seats, 3way power driver
Old Nov 24, 2000 | 01:49 PM
knighthelm's Avatar
Cool Pods
How hard is it to add a tach if you dont have one?
Another thing would adding a digital dash be the same as adding the other?
Old Nov 24, 2000 | 04:01 PM
pods8's Avatar
If you want to add a stock tach I assume you will need a cluster that supports one. The cluster I have was a full one but the speedo and tach are gone, I can give you just those gauges if you want or the cluster and you can probably go pull a tach from the junkyard. After market tach are rather easy to install but I don't know if you can get one that fits in the stock location.
As for the digital dash I'm not experienced in that one, but others have them just ask around a bit.
-pods
Old Nov 28, 2000 | 06:29 PM
knighthelm's Avatar
Cool
Prob find a tach in a yard somewhere, I was wondering bout the fuel gauge? In the non tach model it is located as big a life in the tach spot and on the dash with tachs it is located on the speedo. If I were to replace the speedo and tach and put in all the gauges would I need to change any wiring over for the Fuel?
Old Nov 29, 2000 | 10:18 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Or you can buy an aftermarket tach and put it somewhere by the steering wheel!
Sorry guys, I like the "added gauges" look... probably not what you're all after.
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
