Anybody experienced this with a 2.8 or 3.1 V6 ?
Old Dec 2, 2000 | 05:30 PM
Blade's Avatar
You start the car and when you try to rev it in neutral it will not rev. It's like it hits the rev limiter at like 1200 rpm. Fuel pressure is constant around 50 psi, air gets in there no problem, so I'm thinking spark ? Could it be a bad distributor or module ? My 85 Camaro did this when it was very cold, but it would go away when it got warm. This happens on a 91 3.1 RS however. Any ideas ?
p.s. so far I plugged and unplugged the distributor wires, checked the TPS sensor, and swapped the ECM and memcal with no change in symptoms.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
http://www.truspeed.org/Members/Chev...dmondIndre.htm
Old Dec 4, 2000 | 02:06 AM
jjstealth2000's Avatar
Well heres What Mine did. the 2.8 that I had had a similar problem. somehow I burned a piston and pretty much slaughtered a ring and lost almost all compression causing blowbye. It would free rev hardly at all.
just a suggestion check your compression on all 6 holes.
and if you need to rebuild that 6 spend a few extra bucks and add a mild turbo and crank the compression ratio up a touch (you wont be sorry
Good luck to you.
*89 2.8 bird
*89 TTA
*89 TTA Indy Pace car
*86 TA 305 L98
*83 SCCA road america 383 L98(fun car)
cheesehomer
Dec 31, 2015 08:48 AM
BrianI
Oct 3, 2015 12:57 PM
usafirebird
Sep 29, 2015 11:58 PM
mfp189
Sep 27, 2015 09:25 AM
spartanreaper
Sep 25, 2015 07:22 PM
