Will these Headers work on a Hybrid?
Old Mar 7, 2011 | 04:27 PM
RoosterC's Avatar
Car: 1988 Maui Blue Camaro
Engine: Pea Shooter
I want to buy some Pacesetter Shortys from Summit
http://www.summitracing.com/parts/PSM-72C1206/
But I also want to do a 3.4L FWD swap from my 2.8L but don't know if they will fit considering it's a FWD application. It sounds likely, but I don't want to get that far only to find out they don't fit.
Old Mar 7, 2011 | 04:52 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: Will these Headers work on a Hybrid?
im fairly certain that they do not work...the ports on the front wheel drive heads arent round if i remember correctly
Old Mar 7, 2011 | 05:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can put a sidewinder into a rear wheel drive car?
Old Mar 7, 2011 | 05:54 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
As Pils said, no, they won't work, but they're about the only bolt-on header available. First, the bolt pattern is too narrow, so you'd have to enlarge either or both of the holes on each runner. Second, the ports on the later heads are D shaped, and the round hole in the primary will block part of it, creating a flow problem. Third, even if you got the WOT-Tech tool to make the header primary the right shape and the flange to weld the primaries to, the primaries are too small. The Pacesetters use a 1.5" primary, and the port, at minimum, requires a 1 5/8" primary. The only headers that would bolt on (enlarging the holes, of course) would be RKSport 4th gen headers, and I still have no proof that these would even fit in our engine bays. Not to mention they're about $200 more than the Pacesetters.
Old Mar 7, 2011 | 06:08 PM
Pillsbry10's Avatar
if you want to do a hybrid youll want to make your own headers...if you cant make headers a hybrid may not be for you
Old Mar 7, 2011 | 09:49 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
No need to make headers from scratch.
Are my posts not being read?
Just modify the flanges and ports when the genIII heads are swapped on.
Old Mar 7, 2011 | 09:57 PM
Pillsbry10's Avatar
im afraid i missed the post you refer to lol
Old Mar 7, 2011 | 10:53 PM
I've mentioned the modification of headers in just about EVERY hybrid thread.
Old Mar 8, 2011 | 06:24 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Six is right, although the 1.5" primaries seem a little too small they will work. Just oval the holes out vertically and bolt them on. The port overlap is extremely small.
These are some longtube headers that i built for a friends 3400 swapped Cavalier, i used flanges for gen 1 heads. You can see that the holes are just ovaled out a little.
http://www.v6z24.com/gallery/d/10618-1/20D_08846.jpg
http://www.v6z24.com/gallery/d/10850-1/20D_10029.jpg
FWIW, the 1.5" primaries work pretty well in his application. That car runs mid 13's off the bottle with some mild porting and a healthy cam.
Old Mar 8, 2011 | 12:49 PM
RoosterC's Avatar
Engine: Pea Shooter
Thanks everyone!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
Wvcamaro
Sep 4, 2015 08:38 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
mustangman65_79
Aug 7, 2015 09:55 PM
