TPS hop-up? Everyone with a chip, read this
Old Jan 1, 2001 | 09:36 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
This is supposedly a new part to Summit this month...apologies to those of you who've already seen it.
I don't have the Summit with me, but supposedly this is a thing that basicallt hops up the TPS. It said something to the effect that, when the throttle is opened to at least 80%, the car acts as if its at WOT, and adjusts the spark curve (or something to that effect).
I know I'm not explaining this well, but do you guys know what I mean? For $80, is this legit? It appears to me that this little thing would allow the chip to kick in sooner, as it makes the car act as if its at WOT, even when its not.
Sure would cure the "got the floor mat shoved under the pedal so my chip doesn't do jack" syndrome
Jason E
'89 Camaro RS 2.8 (Medium Gray Metallic)
Hypertech chip/K&N filters/Accel 8.8 wires, Accel Supercoil/RapidFires
Eclipse CD and 100x4 amp/Boston plates and 6x9s
Alpine Alarm, Keyless Entry
IROC tailights, tinted windows
JasonEE98 on AOL IM
Old Jan 2, 2001 | 02:43 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I saw that too i dono if it will work with a prom chip tho if it does i considerd buying it also i thoguht it was for a 305 and 350 dono if it will work on ours
Old Jan 4, 2001 | 10:49 PM
Jason E's Avatar
Take a look at the ad again if you have it...it says GM, nothing about models...all it gives is 3 different GM options depending on the years.
C'mon guys, SOMEONE must have an idea here...
Old Jan 5, 2001 | 09:58 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The device will "jump" your TPS voltage higher when you get to a certain point in the TPS's travel. That's a description at the most simple terms. A few people have them, but didn't say much about 'em. The part's not that new, it's been in Summit for a year or so; I think it's made by Casper Systems, or something like that? You could search thirdgen.org for it.
I think the consensus on the last discussion re: this part was that it might be cheaper to re-adjust your TPS for a higher WOT voltage.
Oh and you're correct, there is no v6/v8 model-specific model. The TPS changed connectors (and design) in certain years; as long as you order the correct year part, it'll work.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jan 6, 2001 | 05:42 PM
Jason E's Avatar
Thanks for the info Tom...I'm gonna do that search. And indeed, I think it is made by Casper Technologies.
For $89, I'm gonna give it a shot. Apparently, it does actually do something I have no idea how to hop up the TPS any other way (such as the one you stated above).
For reference, how DO you do that?
Old Jan 6, 2001 | 06:48 PM
FAST RS's Avatar
I almost bought it but will it work with a fastchip stage 2 it said something about increasing fuel and timeing if i remeber corectly and i dont wana have adverse effects
Old Jan 7, 2001 | 05:50 PM
Jason E's Avatar
Good point Can anyone shed some light on this? I have a Hypertech Stage 1.
Old Jan 10, 2001 | 09:45 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The TPS sensor re-adjust goes along with the minimum idle re-adjust/IAC reset procedures. YOu should find it in the tech section of this website.
The V6 specs are a bit different then the v8 tpi's. Idle is 0.045 volts, +/- 0.10 volts. "WOT" is 4.5 volts- but I never got that high.
The Prom burning guys tell me that the computer kicks in the PE stage (power enrichment) at a certain percentage of the idle voltage. With this info and their experience, they told me that the computer enters PE at a bit over 4.0 volts. My TPS, with all my fiddling, reads "only" 4.28 at WOT. So according to the PROM guys, my ECM is entering PE, even though my GM service manual says otherwise.
Old Jan 10, 2001 | 02:31 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
This has been an ongoing debate for years. You really only need the TPS to read over 4.0 volts for the ecm to go into WOT mode.
I've seen guys play with their TPS to get the voltage over 4.5 volts, and guess what, no improvement in their ets. In fact, they then had problems with idle. This gizmo just avoids that problem by "plugging" a voltage over 4.5 volts...but it does nothing more than if your stock TPS is reading over 4.0 volts.
Save your money and use the cash to buy the equipment to burn your own eprom. THIS is where you will get results.
Old Jan 10, 2001 | 02:35 PM
Car: Death Mobile
Engine: 666 c.i.
TomP, if you have a scan tool, look at your BLM/INT values when you hit your 4.2+ volts. I guarantee that they are BOTH at 128/128 (which means you are in WOT mode).
People get "hung up" because the "Learn mode" still says "ON"...instead of "OFF" like open loop mode. What they keep forgeting is... WOT MODE is different that open loop. Don't get hung up on the "On/Off" part.. look at the BLM/INT values...if they say 128/128...you are in WOT Mode.
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
NWAsonoma
Aug 18, 2015 05:45 PM
mdtoren
Aug 16, 2015 05:45 PM
