I smell gas
Old Mar 19, 2011 | 05:20 PM
89/91rs's Avatar
Car: 89 camaro rs
Engine: 2.8L v6
Transmission: ?
I smell gas
Just bought a 89 camaro rs. The engine runs good, but i smell gas when i drive...the car seems like it is burning through gas at an abnormal rate...i dont race, or spin out, so what the hell could it be? any help would be great
Old Mar 19, 2011 | 05:32 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: I smell gas
Your car might be running rich, I know mine does, so I smell gas sometimes. But that's something you want to figure out quick.
Old Mar 19, 2011 | 07:18 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Re: I smell gas
I temporarily have my catalytic converter hollowed out till I can get a new one and the exhaust smells like gas, maybe yours is hollowed out.
Old Mar 19, 2011 | 10:43 PM
RT66DAVE's Avatar
Re: I smell gas
There is a fitting with a tube coming out of it in the fuel rail under the plenum on the driver side. this fitting & tube feeds the cold start injector. the gasket below the fitting can leak, i would check it. Also the two rubber lines that feed the fuel rail, you'll see them on the driver's side just behind the a/c compressor, those can leak if not tight, or they can split and leak fuel. those are the causes of gas smell i my have found with my '88 sport coupe.
Old Mar 19, 2011 | 11:50 PM
BiggRedd's Avatar
Car: 1986 Firebird
Engine: 2.8L
Transmission: 5Spd
Re: I smell gas
I thought my gas smell was from my evap system, I was going to block off my charcoal canister and go to a vented gas cap untill I could get everything to replace the canister and purge valve. When I went to pep-boys They let me take the cap out to see if it was the right tread(their system only shows the origional replacement), I took off the locked cap the PO had put on the car and found out it was a vented cap. Since the evap system was installed and I had changed all the vacuum hoses I bought a non vented cap. No more gas smell, and reclaimed about 3mpg. So check your canister, vacuum hoses and gas cap.
Old Mar 20, 2011 | 05:44 PM
89/91rs's Avatar
Car: 89 camaro rs
Engine: 2.8L v6
Transmission: ?
Re: I smell gas
thanks guys, will look into it
Old Mar 20, 2011 | 05:56 PM
ex-x-fire's Avatar
Re: I smell gas
Pull the vacuum hose on the fuel press. regulator, common for the diaphram to go bad.
Put a press. gauge on it to check for fuel pressure leak down.
Twin_Turbo
Mar 14, 2016 10:10 PM
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
